Question about Midway Home Entertainment Rise & Fall: Civilizations At War for Windows
Unable to locate file, the data path appears to be incorrect, pleas check your data path After i open the game
ERROR Unable to open NSF file
Verify that the nsf file is present in the path specified. The TSV file row for that particular user can be edited to enter the correct path to the mail file, and then attempt the migration again.
In most cases, the mailserver name is incorrect, and changing this value to reflect the correct mailserver that contains the NSF file should resolve the issue. If it useless, there is a good program: Lotus Notes Fix Toolbox https://www.fixtoolbox.com/lotusnotesfix.html
Apr 18, 2016 | Computers & Internet
The game's installation seems to corrupt. Try re-running the game's setup file and - whenever possible - choose the 'Repair' option ...
Jun 27, 2014 | Midway Home Entertainment Rise & Fall:...
Unable to open Hard disk drive
try running a check disk to check for errors. In windows command prompt type chkdsk C (substitute C for the letter of the drive).
Has anything happened to these drives such as dropping that would cause it to not be readable? What format is the disk FAT or NTFS?
Hit us up at our techie forum:
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Western Digital Computers & Internet
How to recover memory card password for nokia c5-03
Solution 1:
1. Go to file manager on your mobile
2. In Settings choose system folders,
3. In the System folder, find a file called mmcstore
4. Send the file to your PC using IR/Bluetooth
5. Open the file in Notepad
6. The password you need for your memory card is located within that file
Solution 2:
1. Download and Install FExplorer
2. Insert your card into your phone, without accessing it through the phone
3. Run FExplorer and Open the path C:system
4. Find the file called mmcstore, and rename it mmcstore.txt
5. Copy that file (mmcstore.txt) to your PC and open it in Notepad
6. Your password will be located within that file.
Solution 3:
1. Download and Instal X-Plore
2. Now open the X-Plore and press Zero(0) then check you have marked the
"Show the System Files".
3. After you done the above step now go to the file:
C:/Sys/Data/Mmcstore
4. If you found the above path then press the option "3" to set the Hex-Viewer.
5. Now look the third column you can see the code like ! TMSD02G (c ??"? x???3?3?3?3?3)
Now see the characters between '?' because it is your password 33333.
6. You mayn't able to access the path file:
if you don't set the password for the memory card.
May 12, 2012 | Nokia 3110 Cell Phones
My slcdii file is missing, how do I retrieve it?
Its scl dll file not slc dii.
1. Download, install and run DLLSuite,
2. Click Start Scan button to conduct a full scan for slc.dll as well as corresponding issues
3. Locate to file slc.dll and click More Information. You will reach a web page where you can download slc.dll file.
Tips: Before save slc.dll to its path, please use DLLSuite to create system restore points first as if the file path is incorrect, your system would become unstable, even crash.
4. Click Start, Run and type regsvr32 slc.dll , and then press Enter.
5. Restart your computer
Hope it works for you.
Also use a sytem utility software like ReginOut to avoid such type of errors. It will optimize your PC and fix different operating system errors.
Dec 26, 2011 | E-Machines (T3104) PC Desktop
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
Error message : File is damaged. Rewrite!
Step 1: Start Tally.
Step 2:
Step 3:
Tally asks to select the company to rewrite. Select the desired company to rewrite and then press Enter key.asking-tally-to-rewrite-a-company.png
Step 4:
Rewrite confirmation will be appeared on the screen, press "y" to start rewriting process.rewrite-confirmation-in-tally.png
Step 5:
After rewriting the data Tally creates Tally.rew file in Tally folder.open it in any text editor and go through it about the corrupted data.rew-file-in-tally.png
Sep 15, 2009 | Computers & Internet
SECRETS OF THE OLD CLOCK- NANCY DREW
If I was you, I would check the system requierments (located either on your CD Case or somewhere in your manuel, probebly under the title "System Requierments".) and see if your computer is compatible.
If the game requierments are met, I would try and uninstall the game, and try and reinstall the game.
If you have difficulty uninstalling the game try this program, by clicking on the link. http://www.revouninstaller.com/
This program will help you remove all game data on the computer, and will alow you to reinstall the game.
I hope this helps.
Levi_xx
Jul 07, 2009 | Her Interactive Nancy Drew: Secret of Old...
Incorrect path to INI file
install the game and when it gets to the install on C:\nancy drew click browse and choose program files then install there the game will then run but requires the cd to be in the drive
Jan 01, 2009 | Her Interactive Nancy Drew: The Secret of...
Error #80004004
The problem is with outlook. Have you activated the product?
"The following appointment cannot be written to Microsoft
Outlook due to error 80004004. The item will be skipped."
This error code indicates that the operation has been aborted during reading
of the pst file. This might be a result of some kind of corruption.
Search for a program called scanpst.exe. This is a small utility included
with Microsoft Outlook which will scan your *.pst file (the file that
contains your personal information) for possible corruption and attempt to
repair it. The default location of the file are as follows:
* Windows XP, NT and 2000:
C:\Program Files\Common Files\System\Mapi\1033\NT\scanpst.exe
* Windows 95, 98, and Me:
C:\Program Files\Common Files\System\Mapi\1033\95\scanpst.exe
Note: C: might need to be replaced with appropriate drive letter.
You will need to run it against the .pst file. If you are unable to locate
the path of the .pst file, do the following:
1. Open Outlook.
2. Click File -> Data File Management
3. This should list all the PST files that are present. Click Open Folder
and you should find the storage path of your *.pst file.
Good luck and if theres anything else let me know!
Feb 19, 2008 | HP iPAQ RZ1710 Pocket PC
Midway Home Entertainment Rise & Fall: Civilizations At War for Windows Logo
4,595 people viewed this question
Top Midway Home Entertainment Video Game Consoles & Games Experts
Tony
jasbo
jasbo
richie46
Are you a Midway Home Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
