Question about Samsung SyncMaster 204B 20.1" LCD Monitor
I am looking for the pdf file Samsung 204B fix
I have a samsung 204b monitor that is dim and flickering. I found a post that they used the pdf file and it fixed the problem. I think it was a replacement of certain capacitors in the inverter/power supply. Where can I download this pdf file? Thanks
  • Samsung Master
  • 1,684 Answers
A full repair guide with dis-assembly and repair instructions is available at:
http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Jan 12, 2012
  • 319 Answers
Www.fixya.com/.../t5455613-am_looking_pdf_file_samsung_204b_fix
Posted on Aug 03, 2010
  • muhammad faisal saleem muhammad saleem
    www.electronicskb.com/.../LCD-Desktop-Monitor-Fading-to-White-then-Black
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
When I attempt to bring it back up, or turn it on,monitor screen stays black long time, then flickers, then slowly, ever so slowly, comes into view. Works ok at that point. Happening every time now, and...
The Samsung 204B monitor have a know issue with failing power supplies that cause the exact problem you are having. At first they are a little slow to display a picture and the more you keep using it the longer it takes for the display to come on. The repair is simple if you can solder. Here is a link to a site with additional information on this repair. http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ This Samsung 204B monitor is a great unit with a simple to solve issue. No need to trash a good unit.
I hope this helps, if so please rate our solution.
BuddyMc
Jul 04, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
How do i tell wich version my syncmaster 204b power supply is
If you look at the board, you will see the p/n, manufacturer name, V (version) number. What kind of problem are you having with the monitors.
http://lcdalternatives.auctivacommerce.com/Repair-Kit-Samsung-204B-Rev-00-LCD-Monitor-P1274435.aspx
http://lcdalternatives.auctivacommerce.com/Repair-Kit-Samsung-204B-Rev-01-LCD-Monitor-P1274440.aspx
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 15, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Where is the link for the pdf describing the Samsung Syncmastor 204B repair?
We have a full repair guide for this model posted on our web site. www.ccl-la.com/badcaps.htm
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Oct 11, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204b my screen flickers and is dim on wakeup
Your backlight power supply is about to die. Check out our web page at: www.ccl-la.com/badcaps.htm We have a full repair guide and parts list to do the repair.
Buddy
Corporate Computer
www.ccl-la.com
Sep 27, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor flickers and turns off. samsung syncmaster 204B.
this is very frecuent in all monitors or tv's lcd .... turn on 3 seconds and off the capacitors need to be replaced y sugest a technician
Sep 16, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung, same exact problem - flickers on power up for a few min
This sounds like a power supply problem, how old is the monitor? If it is not new in the last year and is used regularly it sonds like a faulty capacitor in the power supply. If you are aware of the precautions necessary when handling capacitors and a moderatly competent solderer then you can replace then yourself - a complete set of capacitors usually costs around £3 or $5
Jun 27, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B The blue power button is on but the screen is black. When I turn it off and back on it shows the screen for a second then goes black. Can you please help me. Thanks
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
Apr 02, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung Syncmaster 204B
Try to replace C110 and C111 in the power supply circuit. These are 820uF caps and are in parallel. I had slow start and a flicker on this same monitor. Replacing the caps fixed it. Good luck, Ryan
Jul 09, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
695 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
