Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
17.5 hp 42" deck Sears tractor. Parked it in the shed after last mowing, everything was fine. Went to mow yesterday and tractor will not drive plus I have no brake....what happened? Belts are fine, gear shift is working up and down and I can't find any thing obvious. Where do I look from here?
    Brigadier General:
  • 3,911 Answers
If the engine is running normally and your drive belt is fine then the input to the transmission is OK you just have no power output from the transmission. Usually those transmissions give you some signs of failure such as won't go up inclines or the top speed is a bit low. What I would do is first check the linkage from the forward/reverse lever to make sure it is moving a corresponding shaft on the transmission itself. If that is good then I would check the fluid level on the transmission itself. This could well require removing it from the tractor. Often the brake pedal is connected to a small disc on the transmission. While you are checking the shifter input to the transmission, you may want to follow the brake pedal rod back and see if anything is broken or disconnected.
Posted on Aug 03, 2010
How do you level the mowing deck?
There should be an adjustment on both sides of the deck. Move the nut up or down to raise of lower it.
Jul 03, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Turns off during mowing
It sound like its over heating try checking your thermostat
Dec 15, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sputtering Mower
It might not be disengaging the mower deck all the way off. I had this problem on an older model.
May 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
366 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
