Question about Compaq Evo D510 PC Desktop
When i power my compaq d510, the board shows the green lights but not the power light.the switch does not work at all.what could be the problem? Nelson from kisumu-kenya
  • 808 Answers
Its may be ur psu or motherboard fault
Posted on Aug 03, 2010
If the red light on Compaq Evo D510 P4 keeps on blinking and the PC wont start when you try to power your PC then whats the problem ?
Power Supply.
Weak voltage power rail, or more than one.
(There are three power rails for the Power Supply used in your computer;
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail.
Wires with Orange insulation carry 3.3 Volts
With Red insulation carry 5 Volts
With Yellow insulation carry 12 Volts.
Each wire is connected to one power rail in the Power Supply.
{All Black wires are Ground wires}
The Power Supply in your computer is an SMPS. Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply )
I don't know what form factor your Power Supply is because you didn't state which model it is.
Small Form Factor (SFF)
or
Convertible Mini-Tower
or
Ultra Slim Desktop
Post additional questions in a Comment. Also state what model your Compaq Evo D510 is.
Regards,
joecoolvette
Jul 03, 2011 | Computers & Internet
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
My compaq evo d510 cmt keyboard lights flashing constantly
first problem its a compaq go buy something else no seriously buy something else
check your bios settings F10 for compaq if i remember corectly might be F2
http://h18000.www1.hp.com/products/quickspecs/11349_na/11349_na.HTML
http://reviews.cnet.com/desktops/hp-compaq-evo-d510/1707-3118_7-20719364.html
i mean com on 533 bus and dosnt saport multi core cpu's
my 2004 dell 200 mhz buss saports quad core wth
if its not a bios setting replace your keyboard good luck
Feb 19, 2010 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
My compaq dont turn on
check *********** board showing a green light.if light is on then check your system's front button restart&switch on cables are connected properly.
Jan 07, 2010 | Compaq Presario 5000 PC Desktop
Does not display out although Monitor is working fine after checking ram,display card
if the power suddenly went from your board it may have caused a short circuit and effectively killed the motherboard. my suggestion would be to get hold of another motherboard and see if you can boot. if not then it will most likely be your RAM. but since you said the CPU light isnt on at all, it will most likely be a dead motherboard
Jun 02, 2009 | Compaq Computers & Internet
Computer won't start up.
Hi
Its seems it the power pack in the pc.
Mar 27, 2009 | Compaq Evo D510 PC Desktop
Boot problem
Check your Bois and go to in boot sequence option set that on default
Mar 07, 2009 | Compaq Evo D300s (269124-051) PC Desktop
Compaq evo 510 Won't power up.
Could be bad RAM modules. Try swapping out the RAM in the system with new RAM. Install one stick, in one slot. If it boots, that stick and slot are good. Try the stick in each slot to make sure all slots are ok.
Feb 20, 2009 | Compaq Evo D510 Minitower (Open Box)...
Presario will not start
Hi, remove the left side of your case, turn on power and see if you can see a red or green led light on the board, if its not showing then your power supply is faulty. If the light is on then with the power off check the RAM chips are tight. if that does'nt work Then trace the cables from the front of the case, locate which is the pwr switch and unplug that, turn the poweron and then use a small screw driver and bridge the pins of the pwr switch. If this does not work you have either a dead CPU or a dead motherboard. Regards mistyman
Oct 07, 2007 | Generic Memory Compaq Presario SR1215CL by...
Compaq Evo D510 PC Desktop Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
