Question about LG DLE5955 Dryer
LG dryer was making a squealing noise, then suddenly started making a loud noise like gravel was being rolled around in the drum. Could this be a broken belt?
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfhjdg
Posted on Sep 29, 2010
Noise whilr drying clothes
Dryer drum bearing and or dryer drum belt. Any can cause noise, belts squeal, drum bearing is a lot like rocks rolling around.
Jul 06, 2017 | Dryers
Yes I have 6 units of the DLE5955W dryer and one of the units vibrates when the unit is on. I thougth at first maybe it had a loose foundation or something wasn't lock do correctly, but all those...
Hey Ryan,,, did you just buy these for commercial use? Sounds like one of them missed the "balance drum" operation..or the "balancer guy" goofed the set-up..
Warranty should cover it!! .. Don't tell where you bought it its a commercial usage.
May 31, 2017 | LG DLE5955 Dryer
The dryer is making a loud noise when running. the drum is turning. almost sounds like something is rolling around under the drum.
heatman101
6565ggf
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
When we start our dryer it makes a loud noise as if it struggles to get the drum moving. Once the dryer is moving it has no trouble moving, but every time we start it, the noise happens again even if i was...
Is this noise like a loud buzz or hum? If it is it may be the motor draging
and can't quite get going. bearing getting worn.
Also check drum rollers or glides and the idler pully one of them may
be dragging if they are you might put a little high temp oil on it.
Hope this helps..
Jan 25, 2010 | LG DLE2532W Electric Dryer
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Oct 11, 2009 | GE DBSR453EBWW Electric Dryer
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
LOUD SQUEALING NOISE
Most likely the rear drum bearing is worn. There's a "ball and socket" arrangement that supports the drum at the rear and a repair kit for it. Part #5303281153. Should run around $25.fe7bd93.jpg
Dec 27, 2007 | Frigidaire GLER341A Electric Dryer
LG DLE5955 Dryer Logo
1,236 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
