Question about Brother FAX T104 Plain Paper Thermal transfer
When I send a fax, the journal says the result is ok, but person Im sending it to says they did \not receive it can this be right
  • 32 Answers
Change your main PCB board..of your fax
Posted on Aug 03, 2010
Tip
HP All-In-One can send but cannot receive fax or can receive but cannot send
One of the most common problems with HP All-in-One Printers is that they can send out fax but cannot receive or they can receive fax but cannot send. Now, what more could possibly be the problem if you are sure that your connection cables are correct and properly setup? Well, most people don't know that this is more often than not, caused by the ECM feature of the fax.
ECM or Error Correction Mode is used by fax machines during transmission. This feature is used to eliminate transmission problems especially when you have a "dirty" or noisy telephone line or a very poor signal can result to fax failures. ECM mode, when is turned ON is supposed to check for errors and glitches and is supposed to make the reception or transmission of faxes come out successfully.
However, for some reasons, the ECM mode is not supposed to be performing well with its feature. Especially if the user has a problem with the telephone line, the more that they cannot receive or transmit a fax. It is then recommended that your HP All-In-One printer's ECM fax settings be turned OFF. To do this, follow the steps below:
1. On your printers front control panel, press the button with the wrench symbol; this is the Setup button.
2. Press the right > or left < arrow until you see Advanced Fax Setup then press OK.
3. Press the right > or left < arrow until you see Error Correction Mode; again press OK.
4. Press the right > or left < arrow until to select Error Correction Mode OFF. Press OK to confirm.
That's it! You may now try to send out a fax or ask a friend to send you one.
on Mar 07, 2010 | Office Equipment & Supplies
Tip
on Dec 02, 2009 | Office Equipment & Supplies
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
Press Menu/Set, 2, 4, 1.
-OR-
Press Menu/Set, 2, 4, 2.
You can use the Transmission Report as
proof that you sent a fax. This report lists the
time and date of transmission and whether
the transmission was successful (OK). If you
select On or On+Image, the report will print
for every fax you send.
If you send a lot of faxes to the same place,
you may need more than the job numbers to
know which faxes you must send again.
Selecting On+Image or Off+Image will print
a section of the fax's first page on the report
to help you remember.
Note
When the Verification Report is turned Off or
Off+Image, the Report will only print if there
is a transmission error, with ERROR in the
RESULT column.
1 Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
My fax confirmation result says GN. What does
This mean the fax was not received on the number you send it to.It will show OK on the report if it was send.
Jun 25, 2009 | Canon L220 Plain Paper Laser Fax
Cannot receive or send faxes
See user manual for setting ring sensitivity. This may be where your problem is. Hope this information was helpful!
Mar 12, 2009 | Brother IntelliFax-2820 Laser Fax
Retrieving old fax transmissions
Usually the journal only holds the last 50 sends / receptions.
Feb 02, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Sharp Fax uxp 100
It sounds like your scanner is shot. Can you make a copy? Are journal prints OK?
Sep 18, 2008 | Sharp UX P100 Plain Paper Thermal transfer...
Brother FAX T104 Plain Paper Thermal transfer Logo
61 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
