Question about Sony KLV-26S400A LCD TV
My Sony Bravia KLV26S400A has been giving me problems lately. It works normal initally and after a while it shuts itself off and the \"Timer/Standby\" light blinks 8 times. Any idea what the problem is? More importantly, any idea how much it will cost to repair?
    New Friend:
My Sony Bravia KLV26S400A has been giving me problems lately. It works normal initally and after a while it shuts itself off and the \"Timer/Standby\" light blinks 6 times. Any idea what the problem is? More importantly, any idea how much it will cost to repair?
Posted on Feb 24, 2013
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Capacitors are very inexpensive. Less than a dollar a piece.
Hope this helps
Posted on Dec 09, 2010
Model KDL-50EX645. Why does audio fail and it shuts down continually?
Sony Bravia tv turns off and on repeatedly by itself - YouTube
? 1:32
www.youtube.com/watch?v=AuWhoi5--2o
Dec 5, 2014 - Uploaded by troubleshooterrors
Sony Bravia TV turns off and back on repeatedly by itself. Green light glows on Set top box continuously, and .
Oct 03, 2015 | Sony Televison & Video
We have an 80cm Sony Bravia LCD TV that continues to shut down and restart. Any ideas.
The main digital board should be suspected. There are so many other reasons too for this fault. Contact any experienced service technician.
Dec 18, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Bravia TV
If you get a blue screen at turn on and a short time later it shuts off--power supply is ok--set is shutting down as no signal detected to protect the screen.
If using a box first unplug it and wait and plug back--let box try to reboot itself.
Also as a test hook a DVD etc to a rear set of audio/video inputs and go to that input quickly when the set comes on (have DVD connected and on---see if set works that way.
No signal either a problem with the set or the signal source (box?).
Mar 31, 2012 | Televison & Video
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia tv turns itself off
The Bravia would shut-off and restart after about a minute of operation repeatedly. I removed the internet connection cable and the problem stopped.
Mar 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My Sony Bravia KDL-46Z4500 keeps switching off
Power board have problems.Replaced capcitors puff up or burst open,Know how to solders?Or replaced the whole power board buy refurbish power board at Shopjimmy.com,Ebay.com.
Jan 22, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
Nov 30, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
My sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | Sony BRAVIA KDL-40V3000 Television
Do not have user manual and need to run setup
Click Sony Support to download user manual of KDL-32XBR6
Manual has detailed info about initial setup.
Mar 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony KLV-26S400A LCD TV Logo
721 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
