Question about Crosley 24 in. CDC450 Free-standing Dishwasher
Unit not cleaning as well as when new;understand that things wear out;is there any kind of filtration system in unit that can be acessed and cleaned to allow bettert water pressures?
    Problem Solver:
  • 18 Answers
Sounds like the heater element not heating as well as it did also you may need to put it through a hot cycle (empty) to flush out any gunk away.
Posted on Aug 03, 2010
Dolphin triton plus is not cleaning the bottom. it is just leaving two track marks as it moves along.
Sounds like you have an obstruction have you kept the unit clean? Turn off the pump and take the unit apart remove filters wash them clean with a water hose removing the debris from the filter cartridges (usually being held in by a single wing nut assembly) once cartridges are clean put them back in secure the nut and close unit back up my unit used a white powrery substance called diamtious earth not sure how it's spelled but it is ground up sea shells and it aids the filtration system they sell it at home depot or lowes and they can explain how to use it
Apr 13, 2017 | Pool & Spa
Button doest work for my suunto core watch. Help
is the button stuck or non responsive?if it is stuck try and clean around it, if that fails disassemble the unit and clean the housing and buttons reassemble the unit and test it,if it is non responsive then it may be damaged, disassemble the unit and manually press the connector that reacts to that button- if there is no reaction then the unit has malfunctioned, it is normally difficut to repair such damage- take in for repair to a jewelry shop
Mar 29, 2013 | Watches
Error code F61
Hi there, Have you checked the unit for dust or dirt, sometimes things like that can cause components to stop working, things like cooling fans can be adversely affected by dust and dirt. It sounds like the cooling fan inside the amplifier unit - clear out as much dust or dirt as you can find and hopefully this should fix the problem, but if the problem persists then the short described in the manual (which I have researched) will most likely be related to the cooling fan and it's power supply - it may be safer to send it to Panasonic for repairs at this point - especially when it comes to electrical faults. Hope this helps.
Kind regards..
Mar 12, 2011 | Panasonic SC-DT310 System
HOW CAN I CLEAN MY CANON NP6050 CORONA WIRE?
Canon NP 3825 printing problem.The print appears like erase with rubber or fade looking.If problem with corona wires,how can I adjust corona wires?
May 14, 2010 | Canon NP 6050 Copier
I have cleaned my unit but the red light stays on
Likely so these units usually put out ozone into the air in your home which is a known lung irritant. If you truly have indoor air quality issues the only way to properly attack it is through three steps
source control - what's causing it(uv lights to kill it usually)
ventilation - bring in fresh outdoor air and exhaust stale indoor air(ERVs and HRVs depending on your climate some dealers won't sell these if they don't offer it to you they are dumb find someone who does they are Recovery Ventilators)
filtration - a whole home filtration system (look to dealers who carry Lennox who is the only company with a 100% ozone free product line and the highest filtration rates available on the market "MERV 16" filters or Trane is ok as well as Carrier systems)
Sep 19, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Dishes come out cloudy especially the glasses. Small amount of water remains in unit at end of cycle (which we drain each time before commencing cycle). We have had repair person here twice to clean unit...
the problem is from hard water. there is a new product out just for this problem. its called the dishwasher filtration system. it filters the hard minerals out of your water before they enter the dishwasher. it has a money back guarantee and works amazing. check it out at www.dishwasherfilter.com
Jul 04, 2009 | Kenmore Dishwashers
115volt AC recharging
Ok in that case it is dirty at the condenser side of the unit. To clean it is a little involved as you need to pull unit out of case and take some housing parts off. But if you take it apart and look at the condenser coils you will see a blockage of air flow across coils. Refrigerant doesn't wear out of just leak out once it is in system good till unit goes bad for good. When you clean the coils use a nozzle and try not to point at angle keep it square to surface. I have cleaned bunches of window units and you will not beleive the difference it makes it will work like new. Any ?'s just get back with me glad to help. ken
Apr 18, 2009 | LG Heating & Cooling
Cd player skips
To clean the cd will involve disassembling the main unit which I dont recommend as things are tightly crammed in and difficult to get to.
As for adjusting you will need an oscilloscope and a deep understanding of cd players if you dont want to risk burning your laser out.
If you do decide to clean inside the player, use a good quality camera lens cleaner with some lint free swabs, this will often improve things if the player has been used in a smokey enviroment.
Apr 05, 2009 | Sony DHC-MD333 Shelf System
Hard disk acess problem
Hi, What the message mean is that Windows can not read/understand the filing system (something like the Table of Contents in a book) and therefore do not which and where are your files in the 80Gb. A few things you can try: 1. Run Windows Scandisdk on the Hitachi 80Gb; 2. Run any third party disk check/utility such Norton Disk Doctor. Alternately, you can use a file recovery software (such as GetDataBack) to recover/copy all your important files from the 80Gb and transfer them to another mass storage device. Thereafter, you can re-partition and re-format the said Hitachi to start new/fresh/clean. Hope this be of some help/idea. Post back how things turnes up or should you need further information. Good luck and kind regards.
Oct 05, 2007 | Hitachi TravelStar 80GN 80 GB Hard Drive
Dishwashers Logo
76 people viewed this question
Top Crosley Dishwashers Experts
Andrew Taylor
Andrew Taylor
majorbean
Level 1 Expert
southside773
Are you a Crosley Dishwasher Expert? Answer questions, earn points and help others
