Question about Garden
Engine dies after pressure builds
Pacific hydrostar 65078 - new, used once. engine starts fine but as soon as pressure starts to build in pump (when I pull trigger in wand), it kills the engine. after this it will not restart and i feel a lot of resistance in the pull cord. If I relieve pressure and unhook the hose, it will pull easy but still won't restart until it cools down.
2 Suggested Answers
SOURCE: Help! i have a pacific hydrostar 65078. Engine
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Posted on Nov 23, 2009
Throttle linkage diagram for pacific hydrostar pressure washer 4 hp
For a throttle linkage diagram, contact Pacific Hydrostar directly.
Apr 21, 2017 | Garden
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Apr 03, 2015 | Computers & Internet
Hydrostar manual
If it doesn't have a pressure switch, install one.
Nov 30, 2013 | Plumbing
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
2002 cavalier was running fine then just died. Will start but wont stay running. Fuel pump?
12.72 is what some new batteries have for a week or so
Little high
Only you know how old the battery is,4 years & it may
be bad,happens,& the voltage can go up when bad,oddly
If your into the fuel pump thing,put a pressure gauge on it
Don't guess. Can't hear pressure build.
Sep 29, 2012 | 2002 Chevrolet Cavalier Coupe
Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
Jul 09, 2011 | Plumbing
Have to spray starter fluid in the intake to get to start. once started runs fine, why?
This sounds like a weak fuelpump, and take a while to build up pressure, the starting fluid get the engine running until the pump builds up pressure, i would have the fuel pressure tested and i think you will find that its bad. good day.
Jun 19, 2011 | 1996 Ford Explorer
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 | Garden
Started pressure washer first time this year. Engine started on first pull. turned off choke, a small amount of mist came out nozzle at the beginning. It looked like it was trying to build pressure. You...
The bypass valve in the pump has stuck. Very common problem.
The valve shuts off additional water input once the pressure builds up.
The O rings in the valve deteriorate and stick in the position so new water can't get to the pump.
Rebuild the valve with new O rings and it will be good as new. Clean the bore of the valve when you have it apart.
May 02, 2010 | Briggs & Stratton Power Products 5,550...
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
Nov 20, 2009 | Garden
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
