Question about HP Compaq Presario 6310US (DA201A#ABA) PC Desktop
My computer displays an insufficient virtual memory notice, even if i am only running internet explorer
  • 808 Answers
Clean up temporary files and do defragment and clean ur registry error by using reginout it will solve ur problem
Posted on Aug 03, 2010
    Scholar:
  • 104 Answers
You just try increasing your virtual memory in your system. Right click on My Computer, click the advanced tab. Under Performance click on the button called settings. In that popup, you will have an option to edit your virtual memory. Try increasing it and then see whether the problem persists or not...
Are there any recommended bios settings that are different from the default settings?
If the laptop randomly runs extremely slow - it's almost certainly due to a background process using up the computer's resources. Run Process Explorer to find out -which- process this is.
I know you said you've already eliminated this as the cause - but I believe you missed it due to the random nature of this problem.
No BIOS setting will resolve this problem.
Aug 15, 2014 | Dell Latitude E6520 Laptop Computer 500 GB...
Why is my computer running so slow
Your RAM in laptop maybe less so try increasing RAM.... increase virtual memory
Jul 22, 2014 | ASUS Computers & Internet
"Virtual Memory Low" error message on IBM Thinkpad T30
Right-click on "My Computer", goto "Properties".
Click the "Advanced" tab, and click the "Settings" button under Performance.
You will see Virtual Memory under there. Click the "Change" button, and switch to "Custom size".
Initial size: 500
Maximum size: 2096
Click the "Set" button, close everything out and restart the computer. You should notice a difference. If you have any questions, please feel free to comment! Please don't forget to vote! Happy Thanksgiving!
Nov 25, 2009 | IBM ThinkPad A31 Notebook
System error, insufficient system resources exist
1) Install CCleaner and run it.
2) Right Click on "My Computer", Select properties > Select Advanced > Click Settings under Performance > Select Advanced > Under virtual Memory Click on "Change", Select " System Managed Size" and Click on OK and exit. Reboot your System. It should be fine.
Nov 15, 2009 | Acer Aspire™ T180 PC Desktop
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Virtual memory
Your hard drive is getting to full for it to be used as virtual memory
When normal memory gets used up windows uses the hard drive as memory ans if insufficient room on hard drive is not available you get this message.
Solution.
1) delete programs from hard drive to create more space
2) Install new hard drive and transfer programs to it. creating more room on C drive
3) If hard drive is already partitioned and 2nd partition has a lot of free space transfer Virtual over to it.
Go to Start / Control panel Open The System folder go to "Advanced" "performance settings"
Then to "Advanced " Click on change and set Virtual memory to new disk.
Set maximum and minimum the same at 3 times the amount of normal memory you ave
Jan 05, 2009 | Computers & Internet
Slow computer
Add more memory and run an anti virus and anti spyware scan
May 18, 2008 | Dell Dimension 4600 PC Desktop
Temporary Internet Files
Temporary internet files could harm your pc if the files contents virus, this could also slow your pc because if you have files that was infected with virus specifically the application files. Those files were automatically load into the services and in the processes and also in the start up without your consent. If all these files will run in the system this will cause " a low virtual memory" because the memory speicified was use by these useless and annoying application.
If you encounter these problem i would suggest that scan you computer with a potent antivirus, you should empty the temporary files and the recycled bin.
If you are sure that the computer is virus free and still encountering the "low virtual memory" you can increase your virtual memory by doing these:
1 right click my computer and then properties
2. click the advance tab
3. in the performance., click setting
4. then " advance tab"
5. in the virtual memory click change
6. check custom setting
7. in the initial size double the size of your memory
7. maximum double the initial size you setted.
If these will not solve the problem i would recommend you to format and reinstall your system.
Hope this help
Jan 22, 2008 | Computers & Internet
Internet explorer not opening (memory problem?)
if your system is running low on memory, the pc will not be able to run the programmes as normal as it will use virtual memory which enables the system to open up programmes that you use regularly without searching for the start up files reciding on the hard drive, but if your system is low you will get these screen messages. Either upgrade the system with more memory or check what programmes you have running on start up using your memory, press start>run, then type msconfig and look at the start up tab and untick any unnecassary programmes that start up,then click apply for a restart, as this will release some of your memory. On the other hand there may well be a problem with internet explorer itself also, so you can download the latest IE7 from microsoft if you wish and see if this solves the runtime issue
Aug 24, 2007 | Toshiba Satellite M55-S331 Notebook
HP Compaq Presario 6310US (DA201A#ABA) PC Desktop Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
