Question about Hotpoint Washing Machines
Hotpoint wf860 fault code f11 - Hotpoint Washing Machines
CMV9
  • 594 Answers
SOURCE: Hotpoint WF860
here is the list of code meaning from hotpoint.
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a service engineer
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer.
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a service engineer.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a service engineer.
  • F41 - Water level detect sequence incorrect. Book a service engineer.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a service engineer to re-programme your product.
please do not forget to rate and comment about your experience with fixya.
Posted on Aug 17, 2008
  • 200 Answers
SOURCE: Hotpoint ultima wt741 F11 fault code
HI
There are several reasons why a Hotpoint door could be jammed shut. One of them is the part you describe which is called the ******. With some older Hotpoint models, there is a cable that runs from the door interlock to the motor. When you operate the door catch or button, this part "pecks" down onto the drive belt or the end of the armature's shaft. If the drum is moving, the ****** will slip on the rotating belt or armature and disengage the door interlock. If the drum is not moving, the ****** meets resistance and the door opens. Therefore if the ****** has come off, or is loose, it can stop the door opening. When you attempt to open the door does this part move?
Other things that can stop the door opening are -
  • A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
  • If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
  • A faulty door interlock
  • The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank you
Posted on Dec 06, 2008
GodBlessU
  • 3513 Answers
SOURCE: f11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
Posted on Jul 09, 2009
  • 86 Answers
SOURCE: where is the filter on a hoitpoint ultima wf860
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is under the rear of the machine inside the sump hose. Remove the lower rear inspection panel and tilt the machine forward, keep it tilted by placing a tin of peas or something under it at the rear. Now put a shallow bowl or dish under the sump to catch any water that may still be it the drum and remove the retaining clip. Pull the hose free from the tub and the filter is inside. (Work safe and remove the power plug from the wall before commencing any repair) For more tips on repairs use this link selfix-uk
Posted on Mar 11, 2010
SOURCE: HOTPOINT ULIMA WT721 FAULT CODES
my hotpoint ultrima wt721 has stopped with f-5 showing the door has stayed locked wot do ido
Posted on Oct 24, 2010
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
FAULT CODE F-03 ON HOTPOINT WASHING MACHINE WF860
i believe that has to do with thermostat circuit. bad thermostat or wiring
Apr 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
What is fault code 3 please on a hotpoint wf860
The fault code indicates that wash thermistor is open/short circuit .
Thermistor is inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature.
With this fault, the thermistor is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately,you need to call technician to solve this problem.
Hope this helps.
Thanks for using Fixya.
Dec 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima super silent is occasionally showing the warning sign F11. Can you tell me what this sign means?
F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
Jul 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
F11 fault code
Nov 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
257 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
