Question about KitchenAid KGST307 Gas Kitchen Range
Kitchenaid Superba Gas Range
Since last couple of weeks, I found oven to be turned on itself. I tried unplugging and checking the programing but no use. So I finally disconnected the AC line.I think it may be a control panel problem? By the way, when it is plugged, display is erotic and few lines are not displaying. Any suggestions? Thank
  • nshaikh Apr 25, 2008
    Thanks a lot. Where can I find the control board and do you what is the part number? Thanks
Buy the simple gas stove this new techonology is just a money making. control boards and all the parts are so exppensive that a simple white or black model will work just the same. boards run from 180 to 280 depending where it is purchase, but replacing the board it does not solve the problem but why the board went bad?????? and you put a new board and the new goes bad againg then what....
Posted on Aug 20, 2008
  • jamc7 Aug 20, 2008
    I have te same problem with the whirpool accubake model the oven does not work because of t he control board but if I do not plugg it the ignitor does not work. in my case i lefft it pluged in. so my spark ignitor would turn the top burners. I am begining to see that my best option is to buy another one but with out the high efficient parts that cost a lot. with the 250.00 that I would probably pay for the board I coould buy a new one
I have a duel range. pilot light went out on stove top. can only light with match. Can pilot be re set? Thanks
Posted on Jul 16, 2008
    Genius:
  • 1,073 Answers
Contro board is bad replace it leave power off untill replaced
Posted on Apr 25, 2008
Oven not working, possible cause
check gas meter outside see if some persons unknown has turned of your gas meter
if gas hot water check if you have hot water
Jun 04, 2016 | KitchenAid Kitchen Ranges
I need a oven bulb lens for my Kitchenaid Superba. I think my model is 9752834A. I need two of them. The one is have has B-1 on it.
Unfortunately, 9752834A is not a model number for the KitchenAid Superba. Usually the model number will have 4-5 letters, 3 numbers, 2-3 more letters and then a final number. Look inside the oven door for a plaque with the model number. With the correct model information, you can see if the lens cover is available.
Next, Kitchenaid ovens either have a rectangular (for models that use halogen bulbs) or circular (for models that use an incandescent bulb) lens cover. I've found three lens covers for Kitchenaid products at RepairClinic.com: http://www.repairclinic.com/Shop-For-Parts/a13b121c48/Kitchenaid-Range-Stove-Oven-Lighting-Light-Bulb-Parts . Check if http://www.repairclinic.com/PartDetail/b121p13/Kitchenaid-Range-Stove-Oven-Light-Lens/9781049/748782?ss=a13b121c48&mr=0, http://www.repairclinic.com/PartDetail/b121p13/Kitchenaid-Range-Stove-Oven-Light-Lens/4452163/589998?ss=a13b121c48&mr=0 or http://www.repairclinic.com/PartDetail/b121p13/Kitchenaid-Range-Stove-Oven-Light-Lens/4375318/584498?ss=a13b121c48&mr=0 look like your model. RepairClinic.com does not have the model numbers. However, Appliance Parts Pros list most of the same parts and has a model number compatibility checker, http://www.appliancepartspros.com .
I hope this helps.
Feb 01, 2015 | KitchenAid Kitchen Ranges
KitchenAid Superba Gas Range error code F3 E0 when trying to strat the range
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse Good luck
Nov 27, 2010 | KitchenAid Kitchen Ranges
Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
My mother has a Kitchenaid Superba Dryer, gas, everything seems to work, but the unit won't heat.
WELL ITS 1 OF A COUPLE OF THINGS NO HEAT KITCHEN AID USES A THERMAL FUSE IN THE BACK OF THE DRYER CHECK THAT FIRST USE A MULTI METER FOR THAT ALWAYS UNPLUG ANY APPLIANCE WHEN DOING ANY WORK ON THEM IF YOU HAVE A GLOW DOWN ON BOTTOM IT COULD BE THE FLAME SENSOR IS BAD OR GAS VALVE COILS ARE NOT LETTING THE GAS OUT OR YOUR GAS IS OFF AT MAIN FROM HOUSE GOOD LUCK GEORGE
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Error code F2E0 stuck key
I had the same problem 1 week after I had the range installed. Called Sears (where I bought it) and they had a tech come out. Tech took a look and said there was nothing they could do, that the entire range needed to be replaced. So the replacement just arrived yesterday, they installed it and the fan inside the oven has been running non-stop ever since. Time to call Sears again. So frustrating. Are these ranges lemons??
Oct 28, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Jan 15, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
434 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
