Question about Dryers
The heat has gone on dryer cant find reset button for thermostat
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerthe heat has gone on - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gifElectric2_bithe heat has gone on - 2_bing.gifass= Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 03, 2010
My Fisher Paykel DEGX1 US dryer has no power after I reset the manual thermostat and vacuumed lint from inside the dryer and outlet pipe. It beeps when I plug it in so power is coming to the unit.
if the unit got backed up with lint and over heated then its a good chance that the Non resettable safety temperature switch has gone , you'll find it just by where the pipe exits the dryer , should have two wires on it and should be about the size of a nickel id bet its open .
Dec 16, 2016 | Fisher Dryers
Tip
No Heat on Dry Cycle - Check Thermos & Resuse Them!!
Once you have established if the problem is the thermostats, remove them from machine. In the centre of the plastic disk on the back of thermostat dead centre between the terminals is a little indentation, this is where the reset button used to be. Use a 1.5mm drill bit and CAREFULLY drill through this indentation through the plastic casing, when you have gone all the way through, place a 1mm dill bit through the hole and press down, you will hear a little click - Congrats - you have just reset your thermo!! Refit and test - Worked like a dream for me.
on Sep 18, 2007 | Hotpoint TDC32 Electric Dryer
My samsung dryer dv330aew/xaa wont heat up is there a reset switch?
you can check the element with a multi meter for continuity. may also want to check the hi limit thermostat and the cycling thermostat, do u have full voltage at the terminal? sometimes a tripped breaker will give you half voltage say 110 instead of 220 and what u get is enough power to run the dryer motor but not the heat as it takes a full 220 to run heat
Sep 08, 2014 | Samsung DV330AEW Dryer
Do a tumble dryer have a reset button once you have changed the thermostats?
check the heating element they might be the problem if they are not getting any power or are open.
Aug 27, 2014 | Hotpoint Dryers
No heat fom dryer
Mike, These dryers temperatures are controlled by a thermostat if the thermostat fails there will be no heat generated. Some thermostats are re-setable. If the dryer temperature becomes excessive it trips by popping out a button on the top, which can be re-set by pushing down the button on the top, until it clicks back into place. TURN OFF ALL POWER and UNPLUG THE APPLIANCE BEFORE ATTEMPTING THIS OPPERATION.
Oct 11, 2012 | Whirlpool Dryers
LG DLe0442W Dryer working but no heat at all.
Check the heating element. That is were the fault is coming from.
Jan 09, 2012 | LG DLE2532W Electric Dryer
Dryer is spinning but has no heat we have found suggestions on the web to reset the dryer's thermostat by pressing a reset button..... However we are unable to locate this. Any suggestions as to the...
hello. the reset button usually at the back of the machine if there no heat check heat sensors at the back of the dryer with a multimeter there are 2 of them if 1 of is faulty change both of them hope it helps
regards
shaun
Jan 03, 2011 | Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
White Knight tumble dryer making a clicking noise when on & has no heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
utube.png You-Tube video "XNxE9eXx2Rk" placeholder (do not delete) utube.png
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
May 02, 2009 | Dryers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
Marvin
Marvin
