Question about Philips 60P8341 60" Rear Projection Television
Red all over screen
My tv has red all over the screen tried to adjust but with no results .
  • Rc Overkill Apr 28, 2008
    I can not get te screen to a black and white. I have tried the convergance and still nothing. The adust on the bulbs make a diff in the blue and green but not the red. Red just overpowers all.
    Yes I did do a hard reset with no results.
    President:
  • 2,712 Answers
Hello Rc Overkill,
Try this procedure:
Adjust the green & blue CRT screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white picture. Now adjust each CRT screen so that you end up with a true black & white picture. Then adjust each focus control to get a sharp picture, and adjust each CRT focus one at a time for clarity by covering the other two up. Then go back into picture adjust and turn color half way up, you should see a better picture.
If you cannot get the blue & green to even out to a black & white screen you have other problems such as faulty CRT card on back of tube or it could even be that the video IC is faulty. If this is the case, then you may have to get a competent local technician to check the TV and get the necessary parts replaced.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 25, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Apr 27, 2008
    Just checking to see if your issue has been resolved…If it has,
    please take a moment to close this problem ticket with a FixYa! rating. I would
    be very grateful for your gesture of appreciation.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    It appears that you may have to replace the CRT's or the convergence chip. I recommend that you get a qualified technician to do this, as it is not that simple if you are not very familiar with electronics and soldering.
    If, however, you'd like to try this yourself, HERE is a clear step by step procedure with pictures.
    If your TV is still under warranty, then the best thing to do would be to take it back to the shop and get a replacement.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Apr 30, 2008
    post them here.
    Cheers!
    IrishDruid
  • 2,335 Answers
If the red is showing like a 3D image and the video looks like the one from this link. The info on what part needs to be replave is also found here.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
  • Philips Master
  • 13,433 Answers
This is a hardware side fault which needs service.
The red CRT is getting weak. I would recommend you let a professional do the job.
    Genius:
  • 3,422 Answers
Did you try a hard reset.Unplug qll the cords from back for 4hours and then put them back and see if it helps.It is a convergence problem may be.You will have to call a tech to get it repaired.
Goodluck,
Please don' forget to rate the solution
Philips hd tv monitor 51pp9303h/17 dp TV 345 347he10839 TV receiver 3135020592 my screen is red and I tried to adjust the color nothing happen it still red can I fix myself
The model indicated is a older rear projection set.
If you go to a program that is black and white and turn the color off the screen should be something close to black and white.
There is a way to adjust the red screen down but it takes two people.
If you want to know how and what is involved let me know.
SD TECH
Jan 17, 2012 | Philips Televison & Video
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Lot of red streaks across screen.Try to adjust convergance, blue aligned perfect but the red didn't
possible fuse. if the red is curved or bent, if the red is straight try covering tv with blanket so the sensors get a good reading. again if the red is bent, and fuses are good..... bad convergence ic's.... local service center
Nov 24, 2009 | Hitachi 43FDX01B TV
My pictures are always to red
The screen control setting may need to be adjusted - the screen contol is a service adjustment and is located internal to the TV. If you turn the TV to a blank channel or video input with nothing connected is the prevailing color red? if so adjusting the screen control may help.You would have to take off the front panel and remove the covering- let me know if you want to go ahead and I'll guide you further - caution since high voltage is present in this area.
Sep 27, 2009 | JVC AV-48WP30 48" Rear Projection...
Too much red in screen on Large Screen Projection TV
Try to adjust the convergence in the adjust menu. If this doesn;t help then you probably have a defective convergence board. one or more of the convergence ic's has to be replaced.
Jul 07, 2009 | Samsung Televison & Video
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 51H84 51" Rear Projection...
Bad color
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Philips 60P8341 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
