Question about Hitachi 61SWX10B 61" Rear Projection Television
When we turn the TV on, it clicks on and off about 100 times (this number of times is growing every day) before it will finally stay on. What do you think our trouble is?
  • Hitachi Master
  • 1,527 Answers
Hello it sound like there may be dry joint or a faulty capacitor could cause this problem
regards
shaun
Posted on Aug 03, 2010
How do I fix my LCD TV that shuts off about 10 minutes after turning on?
Hi Mr. Joe,
It is not the power supply, it is the main board which is causing trouble. I had to replace the main board in a Samsung LA32C480 for the same fault some time back.The main board stops working ie gets 'HANGED' after some time.
Sep 11, 2015 | Samsung Ln40b650 40 1080p Lc ln40b650 /...
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Once the TV is turned on, the sound and picture disappears and replaced by a blank screen. If one turns it off again and on imediately the picture and sound returns. This may happen several times in a row,...
Could be ethier one the dish box or the tv itself have cold solders joints on the FBT-Flyback transformer.That the big black block of plastic with a red wire with a black cap hook to the CRT-(tv tube).Call ur tv Dish box customer service,get a replacement box.See, if this will solved ur tv problems.If not,than the tv must be taken aparts and must have tools like a soldering iron,a roll of solders,also must know basic soldering.Resolders all the coldsolders joints on the FBT for a better High voltages contact to the CRT-(tv tube).This problems,will be solved.
Dec 03, 2010 | Philips Magnavox 27MS343S 27" TV
Sansui tv shuts off by itself after being turned on.
the relay on the power board needs to be replaced; if you feel confident to do this:unplug the tv wait about a 1/2 hour then remove the tv's case carefully look for a small black or, brown box about 1/2" x 1" x 1/2" this relay should have a designation such as Rly 1 printed on the circuit board it must be unsoldered and, removed the numbers on the relay can be entered into a search engine to find a replacement
May 03, 2009 | Sansui TVM1316 13" TV
Sony KV-32XBR96S Wont power on,Just makes clicking sound
I have the same problem with the power button clicking on and off was there a solution? Is it worth fixing?
Nov 30, 2008 | Televison & Video
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TruFlat TV
Be happy to explain how I fixed the problem.......please send $40.00 and I will forward the solution!!!!
Mar 03, 2008 | RCA Televison & Video
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Hitachi 61SWX10B 61" Rear Projection Television Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
