Question about Minolta Maxxum 700si 35mm SLR Camera
Actually a minolta maxxumm 330si - older camera
I haven't used in years, replaced the battery but when i depress the button to shoot a picture, it will focus back and forth, but don't snap the shot.
  • 1 more comment
  • Stan LaPointe Jan 13, 2009
    Similar problem with some added details. The view through the view finder is very dark although visible. AF goes to both extremes and then stops in the middle of the range unfocused with green dot flashing. Will trip shutter in MF. Have tried 3 known good AF Minolta lenses. Seems like it should be an obvious problem but I can't see the solution.
  • Stan LaPointe May 11, 2010
    Turned out to be well known problem with aperture on old Minolta cameras. Years ago when parts were available cost $150 plus parts to repair. Now that these cameras sell for less than $20 the problem goes in the trash can and you chalk it up to "education is expensive".
    I have two now via e-bay. Thanks to all for trying to help. Stan
    Further clarification. Although the shutter will trip in MF mode it is NOT FOCUSED. Green light still flashing. Shutter will fire at any focus point but the picture is not focused.
If the view is dark the mechanism controlling lens opening is likely bad. not enough light and camera cannot focus. Either the control ring has jumped pulleys or the control unit is kaput. Remove lens and look at tab on ring just inside of lens mount by lens release button. that tab should be at approx 2 o'clock position..
Posted on May 01, 2009
I had the same problem. Took it to repair shop and the "gasket" that locks the lens into the camera was cracked. It is a factory part that comes in the camera that is plastic. They replaced it with a metal gasket with a lifetime guarantee. I was told to only use lenses with a metal coupling as well. This was years ago, bu if I remember correctly, it cost approx. $140.
Posted on Mar 04, 2009
Try turning off Auto-Focus.
Posted on May 05, 2008
How do I get the battery to work when it is a new battery? The battery light keeps blinking
Blinking battery is sign of transport problem. Probably failure of the transport gear unit I the bottom. Minolta is out of business so no parts. Some tech do a fix on this, you would have to call your local repair shops. This is too complicated for a novice.
Sep 19, 2014 | Minolta Maxxum 300si 35mm SLR Camera
I used my camera for 17-20 shots but then layed it aside and haven't used it again until now. Will the film be harmed? It's been over a year. That's probably a silly question but can I...
Hi Barbara - The film is actually a digital data file in a digital camera so your 17-20 photos should still be fine on the camera. Data files don't go bad with time.
You can just take up shooting from where you left off originally, just make sure the batteries are fresh and off you go.
Good Luck and happy shooting,
Mikeywaf
May 25, 2011 | Vivitar Cameras
My shutter stopped working on my minolta X 700 how can I fix it myself.
It sounds like the same problem I had your capacitors need to be replaced. They store the energy needed to fire the shutter when you depress the button. Most camera shops are aware of this problem and the can obtain the parts. The replacement requires camera tear down and soldering in the parts. If you don't feel comfortable doing this then take it to the repair shop.
Jun 14, 2010 | Minolta X-700 35mm SLR Camera
Minolta X 300 camera On replacing batteries
on this camera can you lock shutter button down?
may have moved it changing battery.
take out battery may release it
is battery up the right way?
Feb 15, 2010 | Minolta Photography
Trying to find a manual for a minolta maxxum 330si rz camera
Download it directly from Minolta here...
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
or wait for one to appear on Ebay.
Dec 17, 2009 | Photography
Lens will not come off
/sen it to www,flcamearepair;com for est,
Jun 07, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Problem with maxxum 330si camera
I had the same problem. Went to a camera repair store and they said that the electronics needed replacing. Expensive. He suggested I buy a minolat maxxum 7000 on ebay, cheaper, better camera and accepts the lenses from your 330si
Jul 28, 2007 | Minolta Maxxum 400si 35mm SLR Camera
“Shoot and Select” Modes
e “shoot and select” modes allows you to select an image out of a sequence of still pictures you have taken by depressing the shutter button and storing it. This is best for shooting moving objects. SHOOT & SELECT 1: Shoots a rapid succession of 4 still pictures by keeping the shutter button pressed. SHOOT & SELECT 2: Shoots a succession of still pictures by keeping the shutter button pressed. The Stylus 500 will continue to shoot until you take your finger off the shutter button or until the card is full. After shooting, you will have the option to immediately delete the pictures you do not wish to keep.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Minolta Maxxum 700si 35mm SLR Camera Logo
210 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
