Question about Sanyo PLC-EF31NL Multimedia Projector
The powerpoint slide is cut off on the lefthand side.
  • 3 Answers
Use functions and zooming to set it
Posted on Aug 03, 2010
Corrupt data behind Powerpoint 2003 graphs
1. If you run PowerPoint 2003, choose Help, About Microsoft PowerPoint from the main menu bar. If the About screen doesn't indicate that you have SP1 (Service Pack 1) or higher, you should update your copy of PowerPoint. Choose Help, Check For Updates. When the Office Downloads page opens in your browser, click "Check for Updates" and apply the recommended hotfixes and/or service packs.
2. If you run Windows XP and have installed SP1, see Files open as Read-Only after installing Windows XP SP1, Other file/path related problems
3. Open a blank presentation (You can apply the template used for the damaged file, if applicable. That might help cut down on reformatting.)
4. From the main menu, choose Insert, Slides from File (or if you use PowerPoint 2007, Home tab, New Slides (bottom of button), Reuse Slides.
5. Try to insert slides individually if you're not able to insert the whole thing
6. Use software for restoring corrupt .ppt and .pptx documents https://www.repairtoolbox.com/powerpointrepair.html PowerPoint Repair Toolbox
May 06, 2015 | Microsoft PowerPoint Computers & Internet
I want to open powerpoint presentation.
then, go to format -> slide design, choose to show all documents, and choose the corrupt powerpoint file. now, go to insert -> slides from file, and select the corrupt powerpoint file. make sure you are set to insert all slides, and then import. if that works, great! i suspect, however, that you might crash at that point. if so, try repeating the process, inserting specific slides one by one until you find the problem one. after that, save the file, making sure that fast saves are off (in preferences / save).
if you are unable to open your powerpoint files then try pptx viewer tool. this utility recovers your corrupt and damaged powerpoint presentations (.ppt, .pot, .pps, pptx and ppsx formats) from ms powerpoint files. http://www.pptx.viewertool.com/
visit:- http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
http://www.pptx.viewertool.com/ http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
Jan 19, 2015 | Microsoft PowerPoint Computers & Internet
How do I view sidebar on Microsoft Powerpoint? I have a Compaq laptop and whenever I open to view a powerpoint only the full slides pop up, but I can't view the sidebar. I don't have Microsoft powerpo
If you don't have powerpoint installed, then you're probably using the free viewer, or it's a power point 'show' (the viewer is built into the presentation). You can print the slides, but not the individual notes or key pages. One thing you could try is if you have a Microsoft/Hotmail/Outlook.com account, you may be able to open it and print from there. I'm able to do it with a regular presentation, but it might be different with a show. To do this, log into Outlook.com, click the menu in the top left corner, and click Power Point Online, then just upload the file you want to open.
Oct 28, 2014 | Microsoft PowerPoint Computers & Internet
How to make power presentatio?
  • If Office PowerPoint 2007 is already running, save and close any open presentations, and then exit and restart PowerPoint 2007.
Find links to information about saving presentations in the See Also section.
  • If Office PowerPoint 2007 isn't already running, start it now.
In the Slide pane, you can work directly on individual slides. za001093949.gif Dotted borders identify placeholders, where you can type text or insert pictures, charts, and other objects. za001093950.gif The Slides tab shows a thumbnail version of each full size slide shown in the Slide pane. After you add other slides, you can click a thumbnail on the Slides tab to make the slide appear in the Slide pane. Or you can drag thumbnails to rearrange the slides in your presentation. You can also add or delete slides on the Slides tab. za001093951.gif In the Notes pane, you can type notes about the current slide. You can hand out your notes to your audience or refer to your notes in Presenter view when you give your presentation. Note By default, Office PowerPoint 2007 applies the Blank Presentation template, which appears in the preceding illustration, to new presentations. Blank Presentation is the simplest and most generic of the templates in Office PowerPoint 2007. Blank Presentation is a good template to use when you first start working with PowerPoint because it is straightforward and can be adapted to many presentation types. To create a new presentation that is based on the Blank Presentation template, click the Microsoft Office Button za010077102.gif, click New, click Blank and recent under Templates, and then double-click Blank Presentation under Blank and recent.
After you open the Blank Presentation template, only a small portion of the Notes pane is visible. To see a larger portion of the Notes pane so that you have more room to type in it, do the following:
  1. Point to the top border of the Notes pane.
  2. When the pointer becomes a za010205206.gif, drag the border up to make a little more room for your speaker notes, as shown in the following illustration.
Name and save your presentation As with any software program, it is a good idea to name and save your presentation right away and then to save your changes frequently while you work:
  1. Click the Microsoft Office Button za010077102.gif, point to Save As, and then do one of the following:
    • For a presentation that can be opened only in Office PowerPoint 2007, click PowerPoint Presentation.
    • For a presentation that can be opened in either Office PowerPoint 2007 or earlier versions of PowerPoint, click PowerPoint 97-2003 Presentation.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
  1. In the Save As dialog box, in the Save in list, select the folder or other location where you want to save your presentation.
  2. In the File name box, type a name for your presentation, or do nothing to accept the default file name, and then click Save.
Add, rearrange, and delete slides The single slide that is provided automatically in your presentation has two placeholders, one formatted for a title and the other formatted for a subtitle. The arrangement of placeholders on a slide is called a layout. Office PowerPoint 2007 also provides other types of placeholders, such as those for pictures and SmartArt graphics.
When you add a slide to your presentation, you can do the following to choose a layout for the new slide at the same time:
  1. On the Slides tab, click just below the single slide that already appears there.
  2. On the Home tab, in the Slides group, click the arrow next to New Slide.
za001093948.gif The name identifies the content that each layout is designed for. za001093949.gif Placeholders that display colored icons can contain text, but you can also click the icons to automatically insert objects, including SmartArt graphics and clip art.
  1. Click the layout that you want for your new slide.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
Aug 17, 2011 | Microsoft Office Professional 2007 Full...
It's me again! i hade a problem: I would like to make a slide show for a dvd with pictures,and that repeats itself.what program,and how should i use(i have windows xp)!and after i would like put the disc...
Moyea PPT to Video/DVD/Blu-ray Burner
It is an all-inclusive conversion tool that helps burn PowerPoint to DVD and Blu-ray Disc playable with DVD or Blu-ray Disc Player on TV and turn PPT to video convenient for portables, while keeping complete of PowerPoint originals like animations, sounds, slide transitions and video clips.
As PPT to DVD/Blu-ray burner, it features a powerful burning engine, a good host of DVD/Blu-ray menu templates, a cool choice of custom watermarks, and 2 flexible chapter schemes One Animation One Chapter, One Slide One Chapter.
As PPT to video converter, it enables you to convert a PowerPoint presentation to any format of video, e.g. AVI, MPEG, FLV, 3GP, MP4, VOB, WMV, MOV, etc.
Aug 11, 2010 | Computers & Internet
How can I add a .wav file to an entire PowerPoint slideshow? I only know how to add sound to a single slide and want the file to play through the entire presentation. Thanks in advance for your help.
Since you have not mention the power point version that you are currently using I give you the method to embed sound in your entire slide show for both PowerPoint 2003 and PowerPoint 2007.
Lets start with PowerPoint 2003 : Go to the slide where you want to initiate the sound track in .wav form.(1st slide is the default).
Go to Insert> Movies and Sound> Sound from file
Select your .wav sound file and click ok.
After you click OK you will se a dialogue box appearing asking you "How do you want the sound to play". You have to specify that. If you are not sure select "Automatically" so when you land on that slide during the slide show your music or sound will start automatically.
Select Slide Show ->Custom Animation to enter the Custom Animation pane. Confirm Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slide show if you don't want it appear.
Now your sound will play from the first slide till the last.
Life is much much easier with PowerPoint 2007
  • On the slide, click Insert to pick the Sound drop-down list on the very right below the tab. Select Sound from File in the list and choose the specified sound track from your hard drive.
  • Click OK and a message prompts, saying How do you want the sound to start in the slide show? Click Automatically.
  • Now click the sound icon to display the Options tab. Click on the tab, and set Play across slides for Play Sound.
At the moment, it is time for you to play the entire slide show while enjoying this pleasant sound score.
NOTE:
  • The sound you insert must be as long as your slide show. That is, if the slide show lasts 5 minutes, your soundtrack should also be at that length. Otherwise, the sound would be cut off until the slide show ends.
  • It is highly recommend that you take PowerPoint 2007 for your convenience.
Jul 17, 2010 | Microsoft Office 2000 Web Components Book...
PowerPoint Slide Show View Distortion
Well not knowing what is causing the problem, can i suggest a bit of an extreme but very effective method?
You will want to restart your pc before logging into the other account. That will allow you to rename it without problems.
Login to your laptop using an administrator account. Rename your profile to oldprofile.old or similar.
It sounds like its one of those lovely settings Microsoft likes to save in the \applicaiton data\ area of a profile.
Oct 04, 2007 | Microsoft Office Standard for PC
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
Sanyo PLC-EF31NL Multimedia Projector Logo
137 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
