Question about Toshiba D-VR600
  • 186 Answers
Lens could have attracted enough dust to keep from reading a clean signal. First try cleaning the lens. You will have to remove the cover. Dip a Q-Tip in Rubbing Alcohol and lightly squeeze out, then rub on the lens. See if this helps.
Posted on Apr 25, 2008
Recorded mini discs no sound on playback
They should both have the same standard format, but my best guess is you may have recorded one MD in one of the sony longer formats which the Tecnics can't read. The normal MD Decks may not have the old sony extended paly format and even some of the Sony high end decks don't have all of the formats. Sony tried several says to give more recording timje on a disc before migrating to the HiMN standard as an example.
Mar 14, 2014 | Audio Players & Recorders
I tried to record a dvd and was unsucessful. Now the player won't work. I insert a disc and I can hear the player trying to read the disc. After three tries an error message is displayed saying:...
It seems that the Laser Pickup unit has some troouble with it. Just inser an audio CD and see whether the player reads the disc. If it reads, try with an MP3 disc. If these tow types of discs go with and not with DVD disc, make sure that the Laser Pickup Unit has the trouble. It has to be replaced with same type and number. Actually this is a very skilled work, as you have to disassemble and reassemble the DVD mechanism If you have confidence, and have all tools to do this work, you can do it by yoursef. Otherewise, get this set repaired, either by any experienced service technician, or by the Authorised Service Center for Panasonic at your town, I recomend you to get this set repaired by its authorised service center itself. OK.
Oct 26, 2011 | Panasonic DMR-ES46VS DVD Recorder/VCR
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
SONY DAV DZ260, home theatre. Trouble reading the disc.
There is some intermittent connection that is causing the issue. Finding it might prove to be a bear - I would recommend sending it back for another working.unit.
Jun 25, 2017 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Recording on Samsung VR375
Sony is not a good brand for buying DVD's. One option for you with the sony discs will be to try it in a computer and see whether it reads the disc. Also you can try using formatting using a software program like nero and see whether the samsung can recognize the disc.
Next time buy good quality discs...look up some reviews on the net.
Sep 12, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Can't copy disc's
There might be a problem with lens of your dvd get cd lens cleaner to clean that lens..or use nero to make a image of that dvd because if nero fails to copy that dvd you will not be able to copy the disc.....
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Dilip Bagdi
Technical Associate
May 01, 2008 | GoVideo R6530 DVD Recorder
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
Jul 11, 2007 | Samsung VP-DC161 DVD Camcorder
Toshiba D-VR600 Logo
122 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
