Question about Boating
I have a 1990 70 HP Johnson Outboard. It is hard to start, but once started, idles and revs smoothly. It ususally stalls when shifting into forward or reverse, even if it is warmed up. After about 4 or 5 restarts, we finally get it running (by advancing the throttle very slowly), it runs rough for about 20 to 30 seconds then smooths out and runs real sweet at any speed up to full throttle. When we stop and fish, the whole process starts again. The plugs are clean and not fouled. I put in fresh gas, that seemed to help. We did find a small amount of oil in the housing under the carburetors. I haven't changed the gas filter yet (need a part #). I have added startron gas treatment to the gas. Any suggestions?
  • 7 Answers
SOURCE: Hard starting when cold, runs rough at idle and any steady speed.
Your carburetors need to be cleaned. The pilot jets are at least partially plugged.
If you are comfortable doing this yourself, you need to remove the seats, fuel tank, and air induction system before you will be able to get the carbs out. Be carefull when removing the fuel tank, there is a wire harness that will need to be un plugged from it to remove it. The wire harness plug runs under the plastic tray under the seat. There are 3 plastic rivits that will need to be removed to get to the plug. The carbs come out as a pair, and can be tough to get back in the boots.
You need to remove the float bowls, remove the jets, and blow carb cleaner and compressed air through them all. The pilot jets are most likely the only culprit, but you might as well clean everything if your going to all the trouble. You should also blow carb cleaner and compressed air through all of the other passages while your at it. Make sure that you can see through the jets and there is no debris left in them. Make sure to clean the floats, needle valves, and float bowls as well.
Then re-assemble
This happens when the bike sits for long periods. The fuel we get now days has a very short shelf life before it goes bad. Fuel oxydizes over time, and it happens even faster in a small amount that is vented which is exactly as it is when its in the carburetors of a motorcycle. When fuel oxydizes and evaporates, it leaves a gummy mess behind. The pilot jets are the smallest passages that sit in the fuel, so they naturally plug first.
You can prevent this by keeping fuel stabilizer in your fuel when ever the bike will be sitting for long periods of time. Myself personally, when I store one for the winter, I like to leave the carbs empty.
Posted on Nov 26, 2008
jaballou
  • 63 Answers
SOURCE: engine not running
Let it dry out a day or so, perhaps in the sun or a warm place. Try again. If it still won't start, try to find a fuel line or fuel jet and inject some compressed air in to blow it out a bit. Good Luck!
Posted on Dec 16, 2008
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
SOURCE: Is there a diagnostic code "reader" on the Mazda MPV 1993?
I am having a similar problem and my mechanic thinks it's a fuel regulator. Part was ordered and it's being replaced this week. We'll see. Unrelated, I'm/we're having a heck of a time finding an oil pan...mine is very blistered....but it is 17 years old.
Posted on May 18, 2009
  • 10865 Answers
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Posted on Sep 16, 2009
50 hp 4 stroke Johnson 2004 starts easy and idles smoothly.Runs very rough when speeding up.when changing oil in crankcase - no oil in oil filter.What happened?
First..
Shop Evinrude Outboard Parts Johnson Outboard Parts
No oil in the oil filter period?? Does the opening of the oil filter face down.. like the oil will drain out if sitting still?
..You need to talk to a qualified professional.. this could be very serious or SOP..
Jul 08, 2017 | Boating
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Johnson 7.5 hp 1956 model AD-10M shifter wont go into forward
only guessing but sounds like the connecter came apart halfway down the lowerunit open it and see
Jun 12, 2014 | Boating
150 johnson wont idle wot great
start engine while in water with slightly high tickover , remove throttle cable and find throttle stop screw and adjust till 800rpm holding the throttle arm against the stop and see if you can select forward gear without stalling ! depends what size pitch prop your using as you mite need tickover slightly higher but as long as it selects without stalling then ok ! as long as it doesnt jump forward , in gear should be 800rpm + or - 100 max ! if still stalling then possible requires fuel system cleaning !
Jun 03, 2012 | Light Outboard Motor Boat Bass Fishing...
Sep 16, 2009 | Boating
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Outboard boat engine shifting problems
Check for a lose or sloppy shift linkage.
Mar 30, 2009 | Boating
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Boating Logo
323 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
