Question about Peg Perego John Deere Gator HPX Ride on Toy
Peg perego gator hpx gear slippage
I've seen this problem posted by others but have not found a solution. The drive gear in one (or both) rear tires seems to be slipping and makes a loud clacking noise when engaged. Right now it's just slipping. But if we don't get it fixed, I'm sure it's only a matter of time before it stops working altogether. The only thing I know to do is contact the manufacturer for a replacement part.
  • 4 Answers
I had the same problem. but not only the main gear !. . check both of gear boxes (which have metal gears inside filled with oil) mine had broken teeth !!!
And try not to tighten the metal motor gear too much to the plastic gear.
Posted on Aug 06, 2010
Look carefully at each of the gears. Take them apart and I bet some of the teeth are sheared off. Order new gearboxes should fix the problem. This happened to us.
Posted on Aug 03, 2010
Peg perago ride on toy only one tire has power
Does both wheels make a grinding sound when you turn them by
hand. If so, then you might have a lose wire. But if it does not make
a noise then the motor is no good. Each tire on the rear of my grandson's gator has a motor . The tires are independent of each
other.
Jul 17, 2014 | Peg Perego John Deere Gator HPX Ride on...
Battery connectors get hot on gator
are both wheels turning in all of the gears?
May 21, 2012 | Peg Perego John Deere Gator HPX Ride on...
Gear slippage. Horrible sound.
gear box gears are probably sheared off. this happened to ours. Order new gear box--easy to install.
Aug 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Does the motor or gears burn out on the per perego john deere gator?
I replaced the Peg perego gearbox units because it was locking up, but now it runs great, i looked at http://www.mypegperegoparts.com/
and found the exact style i needed.
hope this helps
Jun 05, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Jan 13, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
411 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
