Kenmore top load washer leaks as it fills and drain hose is not an issue. There is a small hole in the plastic hosing where the two hoses meet, but why is water even getting to that point when it should be filling
  • AlishaOG Feb 05, 2009
    My Kenmore 26834 Top Load Washer leaks when filling with water. Is in the same location it has been in for a long time. I changed the exit hoses and this was not the problem. Water seems to be coming from front of the machine somewhere inside. Machine will still fill and function, just makes a mess too. Do you have a solution for this?
  • 145 Answers
As the washer fills the water will go up the drain hose to the same height as the watr fills in the tub. That is why the drain needs to be higher then the tub or the water can just run down the drain.
Posted on Apr 25, 2008
When filling washer water leaks from front of machine there is a plastic box with two tubes can this be the problem and what is it called
if the tubes are black these are part of the drain hoses one from the tube and the other to the main hose.Plastic box is the drain pump and may need to be replaced
Mar 19, 2010 | Kenmore 15864/15862 Top Load Washer
Washer continues to fill and does not stop. is there a level or pressure switch that is problem or something else? Kenmore 80 series
if there is no water leaking from the unit.then stop the washer pull your drain hose up so it is at least as high as the top of the washer make sure not to to take it all the way out of the wall.you should here water draining out of the hose once the water has stopped restart you washer and it should stop filling.if it does not the yes you have a fill valve sensor problem.the drain hose usually always holds some water and during the filling process if the drain hose if very low it will cause the water to start gravity eeding out of the washer that is why raising the hose helps out.i hope this helps your problem.i would like to now how it worked out for you good luck.
Jan 22, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Dec 13, 2008 | Kenmore 24832 Top Load Washer
Water after spin cycle
remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Nov 05, 2008 | Kenmore 24902 Top Load Washer
Ge top load washer keeps filling with water
most common leak point for washers is the level sensor connector on the lower part of the tank, a small plastic hose.
Not a solution, something to check
Jul 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
