Question about Moen YB2218CH Brantford 18'' Towel Bar In Chrome
My Brantford towel bar is loose. How do I remove
My Brantford towel bar is loose. How do I remove from the mounting posts to tighten?
    New Friend:
  • 4 Answers
There is no screw here.
Insert a small flat screwdriver -- small enough to fit fully in the hole -- and pivot it up, so that the tip presses toward the wall. This should easily release the locking tab.
Posted on Aug 24, 2015
  • 454 Answers
There are some tiny screws under the posts. Loosen them and lift the post off of its mount.
Posted on Aug 03, 2010
  • Kevin Murphy
    Kevin Murphy Aug 24, 2015
    THERE ARE NO SUCH SCREWS
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
My hand towel ring is loose. The wall mount is secure but the ball that holds the towel ring and connects to the wall mount is loose and looks like it could fall off.
Usually there is a set screw in the side of the wall mount. If there is loosen that and take the towel ring down. There maybe a second nut or fastener you can tighten up the ball with. If not just buy another one. Some just get worn out over time its normal.
Feb 02, 2012 | Home
How can I remove 24"
for most towel bar and bath accessories there is a very small screw or allan bolt, located on the underside of the post, which holds the post to the mounting hardware and you can simply unscrew it to remove the post and then remove the hardware w/a screwdriver (usually phillips) saying that...i just looked up the installation instructions for moen towel bars and it says very specifically that the posts snap or click into place on the mounting hardware...it also refers to a square hole located on the underside of the post. perhaps we are meant to put a small flat head screw driver in there to release the "clip" and post. here are the installation instructions: http://www.faucetdirect.com/mediabase/specifications/yb2218_5624sp.pdf
hope this helps:)
Jul 29, 2011 | Moen 24 In. Towel Bar...
How can I disconnect the Moen "Brandtford" Towel Ring from it's "locking clip"?
Look underneath the part that is mounted to the wall there should be a real small screw that is holding the cover on. After you remove the cover you can get to the mounting screws.
Apr 13, 2011 | Moen YB2286ORB Brantford Towel Ring In Oil...
The towel bar keeps coming off the brackets. How do I get this corrected?
Hi. Are the brackets (mounting posts) the correct distance apart? For a 24" rail, they should be 26.22" apart (outside to outside). If they are not then they probably need to be moved so that they are.
If they are correctly spaced, are the "notches" in the mounting posts facing downwards? If not, make this so.
If the notches are facing downwards, are the screws tight enough? If, not, tighten screws.
Hope this helps. Regards, Myles
Dec 31, 2010 | Moen 24 In. Towel Bar...
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
My towel bar is coming off of the wall and I need to tighten it to the wall. How do I do this?
Towel bars usually have a base that attaches to the wall with a screw. To expose the screw, you must loosen and or remove a small screw on the underside of the mounts. Once the screw is exposed just tighten it.
Jul 29, 2010 | Moen 24 In. Towel Bar...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Moen YB2218CH Brantford 18'' Towel Bar In Chrome  Logo
776 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
