Question about Whirlpool Washing Machines
The machine is not draining. the clean pump light comes on
  • Whirlpool Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinethe machine is not draining. - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machinthe machine is not draining. - 2_bing.gif"http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 03, 2010
My machine is about 8 years old and it's a WFS1273BW I did one wash and was fine then did second lot and this clean pump light comes up.no idea what to do as there is 10 min left and it's soaking wet.
Clean pump means there is a clog. It is unable to drain. You will need to locate the pump, take off the drain hose and clean out any debris. Water will come out, so use a pan under the pump. Good luck!
Feb 08, 2016 | Washing Machines
Clean pump light keeps coming on the machine is a WHIRLPOOL WFS1071AW 7.5KG
Possible thaat the drain pump is clogged and must be cleaned out as the filter is choked.
so remove the drain and have it cleaned and reset , also check you inlets and drain hose.
Sep 30, 2010 | Washing Machines
My washing machines clean pump light comes on. I have drained it cleaned the filter and the light is still on. The machine will not drain and the pump rotar seems to stick on something then move then...
You will need to remove the pump and check for obstructions inside if none found and it does not spin freely replace the pump the following video should help.
http://appliancehelponline.com/frontloadpumpvideo.html
There are also photo tutorials of other styles.
Jun 01, 2010 | Whirlpool Washing Machines
Awd/d4505 clean pump
hello i'm not sure on your model but they usually sit in 1 of the corners at the bottom of the machine follow the drain hose as this is attach to the pump i hope it helps
regards
shaun
Feb 28, 2010 | Whirlpool Washing Machines
''clean filter'' light coming on, won't drain or spin
If it does not spin now that you have drained the water out, then there is another problem.
Could be a motor problem, control board problem, or any one of a number of things.
Make sure the filter is clean, and that there is nothing stuck in the pump.
Please rate my solution.
Thankyou.
Jan 14, 2010 | Whirlpool Washing Machines
Washing Machines Logo
21 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
