Question about Dryers
I have a dryer that won't heat up ! - Dryers
  • Dryers Master
  • 1,527 Answers
Hello see if there's a reset button at the back of the dryer. if not then 1 of the heat sensors may be faulty these will be at the back of the dryer there may be 2 of them replace them both good luck
regards
shaun
Posted on Aug 03, 2010
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerI have a dryer that - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your I have a dryer that - 2_bing.gifsrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gifElectric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Whirlpool electric dryer
Hello there and welcome to Fixya :
This is a fairly common problem with these whirpool dryers.
I will provide you with the 7 most common things to look for
which contribute to the symptom Dryer won't stop are listed below. Check or test each item and watch any available videos. If you are still unable to solve the problem you may need to do additional research and troubleshooting.
Show all parts for model GEW9878LW0 For the symptom you selected, these are the most common parts or causes, ordered by the likelihood of fixing the symptom.
othercausesandconditions.jpg Air Flow Problem The most common problem when a dryer is slow is when the vent is clogged. If the dryer is slow, check the vent from the back of the dryer to the outside of the house. If that is clogged, clear it completely and test the dryer. If the dryer is slow after the vent is cleaned, clean the internal ductwork of the dryer. This will require some disassembly.
blower-wheel-694089-00918612.jpg Blower Wheel
Item # 686172
The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video $23.40 Quantity:
In Stock
heating-element-assembly-3401338--00621237.jpg Heating Element Assembly
Item # 528055
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity.
Part Testing Video $91.05 Quantity:
In Stock
lint-filter-349639--00685658.jpg Lint Filter
Item # 2659
Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
$38.95 Quantity:
In Stock
moisture-sensor-279366-00565298.jpg Moisture Sensor
Item # 469522
Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or coated with fabric softener. Clean the moisture sensor contacts inside the dryer and th
Oct 11, 2012 | Whirlpool GEW9878LW Electric Dryer
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
Whirlpool supreme lhi 5801 won't heat. The coil turns red but won't ignite anything. I'm pretty sure the gas is on. I don't know what else it could be...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 03, 2011 | Dryers
Won't heat up
If it won't heat it will be either the heating element or the thermostat or the control board.
Aug 28, 2011 | Whirlpool GEW9250 Electric Dryer
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
Maytag MDG8057 dryer won't heat. I unplugged the dryer to use the outlet for something else, plugged it back in, and now it won't heat. Any connection to unplugging it? If not, potential...
Did yall move the dryer? The ignitor is very brittle. Moving a gas dryer sometimes breaks an ignitor with a little age on it.themobilian_2344.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2011 | Maytag Dryers
Kenmore dryer not heating up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | Electrolux AEQ8700F Electric Dryer
Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Jun 07, 2009 | Kenmore 74732 Gas Dryer
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
Marvin
Marvin
