Question about Cameras
It's been 3 years since i've been using my Nikon D40x and this morning I was about to shoot an event, I adjust the aperture to 13 and after that a message show on the screen saying "lens not attached" and I can only use the manual mode but I can't adjust the aperture anymore. what should I do? do I have to bring it to the nikon center for repair?
  • kakima Aug 03, 2010
    May I assume you've used this lens with the D40x in the past? If so, remove the lens and clean the contacts with a clean dry cloth, both on the back of the lens and in the mount on the body. Reattach the lens and jiggle it gently to seat the contacts. Does that do any good?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Sep 17, 2010
  • kakima Sep 17, 2010
    Having gone over a month without a response, I assume it was just a matter of dirty contacts.
How could use vivtar 500mm in D40x. the seller asked me to put the camera in Manaul mode and set off to the shutter priorty to off. I could not find how to set the shutter priority to off in the setting.
A 500 mm mirror lens is a fully manual lens (manual focus no aperture change) using a T mount adapter to your specific camera. The T mount costs some $15. It depends on your camera how to turn off the auto focus and go to aperture priority mode. The aperture on a mirror lens is set, usually at F8, so the shutter is the only item that can be adjusted to get a correct exposure. A digital camera (set in adjustable ASA setting) can change it's ASA to help with getting a correct exposure. Manual for digital camera are usually on the companies' web site.
Feb 22, 2014 | Vivitar 500mm 8.0 Lens Nikon D3000 D5000...
What is the relation of lense maximum apertures and camera settings?
You have not stated which model camera body you have so I can only give you general Nikon information. There is a range over which the automatic settings will work for each camera. In addition, Nikon bodies have multiple sensitivity ranges. On the D90 for example, go into the "Shooting Menu" and open the "ISO sensitivity settings." You will see "maximum sensitivity" and "minimum shutter speed" menus along with the "ISO sensitivity auto control" options. Turn off the auto control option and manually set the maximum (ISO) sensitivity and minimum shutter speed. Also, the Shooting Menu also has "High ISO NR" settings that can be used to accommodate most lighting situations. You need to look in your camera's manual for all the details. The Nikon website has manuals available for all the Nikon products.
Sep 19, 2012 | Nikon D3, D40, D40X, D50, D60, D70, D80,...
Error Press shutter release button again
The usual cause of this problem is the failure of the motor in the SQ (sequence) unit, which also ***** the shutter, adjusts the aperture, etc. The D40/D40x/D60 all use the same part, so this applies to all three. The motor is only available as part of the assembly.
Oct 14, 2011 | Nikon D40x Digital Camera
Why the screen on my Nikon Dx40 doesnt go on- so you cant see wha yo are pictring - so I should see only through the little lense.
The D40x works as SLRs have worked for half a century. You have to compose the picture through the viewfinder. The LCD screen is for menus, settings, and reviewing pictures after they've been taken. The LiveView capability allowing you to compose on the screen is a relatively new development, which Nikon introduced into their cameras with the D3 and D300, introduced years after the D40x.
Sorry if that wasn't the answer you wanted to see, but that's the way the D40x works.
Apr 12, 2011 | Nikon D40x Digital Camera
What shooting mode do i need to shoot a subject clear but the background blurred
If you're using the point&shoot modes, use the Portrait mode. For more control you're going to want the PSAM modes.
What you want is a narrow depth of field. Depth of field is controlled by three factors. The first is the lens aperture: the wider the aperture (smaller f/numbers) the narrower the DoF. The second is the lens focal length: the longer the lens the narrower the DoF. The third is the camera-to-subject distance: the nearer you are to the subject the narrower the DoF.
The easiest way to control the aperture is to use the A mode. This lets you set the aperture and the camera will automatically set the appropriate shutter speed to give the proper exposure.
You can zoom in farther and move in closer (yes, the two are in conflict, you'll have to determine the proper position and focal length for the picture you want).
Feb 14, 2011 | Nikon D40x Digital Camera
Nikon D40X In Program mode (P*) I can not change settings. Nikon's video show it is possible to do this using the command dial. Any suggestions ?
Program: Puts the camera in charge of aperture and shutter speed, though all remaining camera settings are available. You can vary the combination of aperture and shutter speed the camera has selected by rotating the Command Dial.
from: http://www.imaging-resource.com/PRODS/D40X/D40XMENUS.HTM
The camera takes care of the shutter and aperture settings, and you control the other stuff...(presumably white balance, focus points...etc.?). I hav ea D70 and using the thumb wheel, I can, on 'P' mode, set the aperture...but the shutter speed is always 'auto' as far as I can tell.
Best of luck!
Nick Chapman http://ChapmanIT.com
Jan 05, 2010 | Nikon D40x Digital Camera
Manually adjusting camera settings
Assuming you're getting a proper meter reading, after adjusting your aperture, shutter and ISO, you've covered the bases.
Sep 26, 2009 | Nikon D40x Digital Camera
I have a new D40x Nikon. Im trying to use it in manual mode however I can't set the F/number lower than F4.8 is this normal?
What lense are you using? you will not be able to set it lower than the minimum aperture of your lens, assuming it is the 18-55 which has a variable minimum aperture, it is 3.5-5.6 depending on where you have it set, at 18mm it will be 3.5 and as you zoom out it will raise to 5.6.
Dec 03, 2008 | Nikon D40x Digital Camera
Old Lense and new camera
Here is a link to the lens limitations of the D40, same for the D40X:
http://www.popphoto.com/photonews/3543/update-to-nikon-d40-hands-on.html
The camera will not recognize the lens but you can take pictures setting speed and aperture manually. Since you see results after you take the picture, you can make adjustments to correct your exposure
Dec 24, 2007 | Cameras
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
