Question about Hotpoint 24 in. DWF33 Built-in Dishwasher
Our dishwasher made a loud pop the other night, and there was a smell of burning plastic/rubber. Since then it has stopped working. No fuse was blown or tripped it seems to be local to the machine. I suppose I am wondering is it repairable or not. Thank you
    Problem Solver:
  • 11 Answers
You would probably need a whole new motor but the nwith the smell of plastic you may also have a burn hole in the tub. Your best bet is to replace the whole thing. Sorry
Posted on Aug 03, 2010
HI. My Yamaha D80 while playing gave a burned smell and than sound quit. Rest works. I opened rearcover and notice 3rd fuse in the back was blown. Changed it. Blew again. So I stopped fidling around.
If the fuse blows and a smell of burning is present then its obvious there i a fault somewhere ahead of the fuse, the fuse is a protection device.
Oct 08, 2016 | Yamaha Cars & Trucks
Was making a loud noise and then stopped working also could smell rubber burn
Hello Todd, thank you for your post!
From my understanding your Frigidaire washer made a loud noise then stopped working and you also smelled burning rubber. This could be a possible issue with your moto, belt, or pulley. I would recommend contacting a professional technician for proper diagnosis and repair. Since it could be anyone of these underlying issues a technician would be able to pinpoint the problem without multiple part purchases. A technician will have the appropriate tools needed to verify which component may need to be replaced. Hopefully this information is helpful to you. -Matt
Dec 15, 2015 | Frigidaire Washing Machines
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
Bosh SHY56A Dishwasher - Loud Pop and Smoke While
Hey Matt,
Dishwashers are not that complicated.. Turn off the breaker, pull the machine out - away from the wall..(there will/should be at lest two screws in the top edge holding it to the counter.. remove them first.. then pull it out until you can turn off the water supply.. When you are able to completely remove the washer, you should be able (possibly)to see what happened.. Check to see if the washer arm (inside the washer) will turn, if not.. replace the motor.., check to see if the pump belt will turn?.. it could be the pump drive motor or the pump its self..(remove the belt), then see if the motor will turn, check to see if the pump will turn.
.. White smoke makes me think that the belt was turning and the pump NOT turning..that will cause the belt to smoke.. and smell like burning rubber..If the pump will not turn. you have found t he problem... Also ..Check to make sure there is not a knife or some other object lodged in the drain or pump
NOW -- With all this.. Sometimes REPLACING the machine is actually cheaper than repairing the old one!!! Your wife deserves a NEW one!!
Jun 28, 2017 | Dishwashers
Bosh SHY56A Dishwasher - Loud Pop, Smell of Smoke, Stopped
Resistance burned or the control module shorted with smoke.
Sep 02, 2013 | Bosch Dishwashers
87 dodge dakota heater blower stopped workng
The blower resistor will burn and smell without blowing a fuse
Feb 04, 2010 | 1987 Dodge Dakota
Loud bang, smell of burning
hello sir,
there must be a electric short circuit happened in ur machine, plz check all d wires, b4 replacig the blown fuse.
or else u must have connected ur machine to a wrong rated power terminal.
plz isolate ur body from the machine while fixiing this problem, n ensure that there is no leakage of current after u fix it.
thank u!!
if my solution is currect then plz vote me sir
Jul 18, 2009 | Hoover Dryers
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Blows fuze and has burnt electrical smell
Time for a new dishwasher. Had the same problem. Tech came out and threw hundreds at it cause it was under warranty at the time, i didnt pay a dime and ended up buying new one.
Jun 04, 2009 | Fisher Dishwashers
Hotpoint 24 in. DWF33 Built-in Dishwasher Logo
613 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
