Jams for Legal Fax only
I have a canon gp200s that jams only with legal size faxes (not legal copies, and not letter faxes). This doesn't seem possible to me for it to know the difference. It's jamming (fanning) as the paper is exits. Any ideas?
  • beachin
    beachin Jun 25, 2008
    Thanks for the info. I told the service guy about your answer and he agreed. However, when he was doing the repair, he messed it up SOOO bad, that it no longer works. He thinks one of the power supplies must have gone out. I don't remember the maintenance code it kept having, but he said that was the problem. We had to buy a new copier (an HP all-in-one).
    I wanted to leave some feedback to tell you how much I appreciated your feedback. Unfortunately, I'm unable to say if that fixed it or not, since the repairman broke it worse.
  • 42 Answers
Change the separation fingers in the fuser units upper heat roll{teflon coated} use only OEM parts. you may need a service call from a tech.
Make sure the exit rollers are clean and are not obstructed. clean with alcohol.
Posted on Apr 25, 2008
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Redued size of legal contracts on receiving fax sent to
HELLO! THE PROBLEM IS NOY ON YOUR END, THE MACHINE AT THE OTHER END HAS TO BE SET UO FOR LEGAL PAGES.SOME PEOPLE HAVE TRAY FOR LEGAL AND ONE FOR LETTER, THEN THE MACHINE WILL CHOOSE IT AUTOMATICLY. GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFax-4100e Fax
Canon Laser Class 3175 facsimile, incoming faxes are being saved in memory, will not print. Cannot clear error message "check paper size".
The problem is that you have a fax saved in memory that is the wrong size for the paper you have in the drawer. Probably it is a legal size, whereas you have letter size in the drawer.Just place some legal size paper in the by-pass tray to print.
May 11, 2008 | Office Equipment & Supplies
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
Lexmark F4270 Paper Jam Problem
Go to the menu and make sure it is set to Letter and not Legal size.
Oct 29, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
NP 6030 paper jam
It may be this simple:
1- as silly as it may seem, are you sure the size  is correct, if it is a letter size paper and it says legal, it will jam. open the paper tray and make sure the guides are snug againgst the paper,
does it say letter (or legal) for the tray you are going to use, if they do not correspond then look behind the tray inside the machine, is there a paper jammed in the back?
Or not so easy
2-You are having a sensor problem, take a look at the duplex tray,
pull it out and look at the sensors ( black little levers that stick out) are there any pieces of paper, can you move them and they spring back into place?
Oct 22, 2007 | Canon imageCLASS D761 Copier
"wrong size paper"
Change the cofiguration of the size in your fax machine see if accepts them then
Aug 16, 2007 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
54 people viewed this question
k24674
