Question about Home
My waste water pump which empties a bath on the ground floor is now very slow and has blown the inlet pipe out - any advice please
  • 43,501 Answers
Sounds like the pump is plugged.
You either need to clean it or replace it...
heatman101
Posted on Aug 05, 2010
How can you tell if the waste pipe is blocked on a saniflow toile
Yes the bowl will be slow to empty. Try squeezing the white discharge hose as the unit operates, if there is a blockage then this hose will be hard to squeeze. If hose is soft then blockage could be in the toilet pan U-bend in which case fill bowl with very hot water and leave to soften the toilet paper.
Jan 11, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Water leaks from the bottom of the bathtube onto the floor in the bathroom, the kitchen on the other side of the wall and onto the bedroom floor next to the bathroom. This all happens when someone takes a...
assuming it's not someone splashing, check that the waste outlet is not rotating & is tight
check the overflow outlet as above
remove bath side panel and check waste trap & waste pipe from it. check that all joints are firmly together - push joints, twist and push in - knurled nut joints tighten, these joints have a washer which may be cracked or not properly in place - two washers where it joins to a pipe
if it's this area then there will be water drips on the lowest parts
make sure all joints are clean before reassemble - petrolium jelly helps to lubricate the joints to refit
Aug 27, 2009 | Plumbing
Kenmore Washing Machine won't drain properly, overflows at PVC pipe. I can run a gardenhose all day long and it won't overflow. But as soon as the Wash Machine Pump starts to empty the basin I can her the...
Check your waste pipe roof vent.
If it is not free (of dead animals leaves etc) - it creates a suction - rather than a drain in your pipe.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2009 | Kenmore Washing Machines
My fisher paykel washing machine just stopped working - lights flashed (no logical message), water didn't finish draining, and bad burning (plastic?)smell. Unplugged, let dry out (had seen water on right...
Hi it seems that one of the machine motors have burnt out, normally its the waste water pump that has got debris stuck in it, unplug the mains lead and remove the water inlet pipe after turning off the water isolation tap pull out and tilt the machine to access the smaller of the two motors if necessary replace please get an electrician to check the motor for you and reconnect hers hoping this small bit of advice helps you cheers eric
Nov 16, 2017 | Miele Novotronic Premier 500 Front Load...
Install bathtub without existing drain
it is generally not allowed under the water regs to discharge waste water into anything other than a drain.I would suggest you install a discharge pump, typically the saniflow type which will allow you to run the waste across the room and discharge the waste into the vanity basin drainage.Should you choose to install this be aware of the waste pipe configurations shown by the instructions
Mar 20, 2009 | Kohler Overture 5ft Vikrell Bath -...
Water doesn't empty out after wash.
Does the waster water line leading from the dishwasher to the garbage disposal exit the dishwasher upward to the bottom of the cabinet top, before going downward to the disposal? The hose cannot be laying horizontal or on the floor, and at some point, must loop at least 6 inches higher than the dishwasher.
Check that there are no blockages on inlet screens to the pump. Look closely, and don't give up until you can see the pump impeller or the end of it.
Jan 30, 2009 | Belling 24 in. IDW602 Built-in Dishwasher
Water will not empty
Hello
you either have a blockage in the filter or you pump is not working.
how to check is diconnect the waste pipe and lower it to ground level if the water does not empty then its a blockage. if it empties then its the pump.
other things it can be is a blockage where the waste pipe is connected or a loose wire to the pump..
Dec 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washer takes in water and immediately drains it out
See that there is enought pressure from your inlet pipe into the machine, maybe someone closed the wall valve. Plug off the wall socket. Check the filters on both sides of this pipe, clean out. Also clean the inlet into machine.
You said the washer will not fill, but is it coming in, the water that is. If this is the case, your outlet pipe from the bottom of the machine is at the wrong height, it should be at about 3 feet above the ground level; your pump pumps this waste water OVER this height. Check these out.
Nov 25, 2007 | Maytag MAH2400A Front Load Washer
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
