Question about Sanyo Televison & Video
Sanyo 46" 1080.must you use hdmi cable to get best picture?
    Novelist:
  • 132 Answers
Yes. HDMI cables are the best for sound and picture quality with an hd signal at this time than anything else. A lot of people can't see much of a difference using HDMI rather than s-video, component / video, or rf cables but there is a slight difference. You will have to have an hd signal or source such as an hd sattelite receiver, an hd cable box, bluray, etc to benefit fully w/ an hdmi cable.
Posted on Aug 03, 2010
The HDMI ports on my Sanyo DP26647 wil not work correctly
Sounds like your hdmi jacks are ( pardin the pun ) jacked up. Shine a flashlight in the jacks to see if the pins look loose or if the jack has been widened at all.
Mar 20, 2013 | Sanyo DP26647 26 in. LCD TV
When i plug an hdmi cable into the hdmi port on my sanyo tv it says a dvi connection and not a hdmi which i have tried 2 hdmi ports and i cannot get any sound or picture on the tv
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
Jul 22, 2011 | Sanyo Televison & Video
My sister has just bought me a Sanyo 26 inch TV (LCD-26XR9DA) but it won't pick up SBS and ABC jumps all over the place. I have an outdoor antennae and had no problems picking up the channels on my old...
Go to the TV setup menu and autodetect all channels. This should fix it. This is assuming your Sister is not using a set-top box.
In that case, you neet to leave the set on either channel 3 or 4, or use the video/audio input jacks and leave the set on VIDEO IN. The best picture with a non-HDMI set-top box will always be with the AV OUT from the box going to AV IN on the set [the white/red (audio left/right) and yellow(video) connections].
If she is using a set-top box with an HDMI output, connect an HDMI cable to the set and select HDMI IN for the absolute best picture.
Jan 29, 2011 | Sanyo Televison & Video
I ned to know what HDMI to buy for my 50inch sanyo flat panal .I have satilite service How many cables ,whats the best .I have connection diagram and dsl.Just need to know what to buy .It is a SANYO 50...
There are no specific HDMI cables to buy for particular models. While there are a variety of different kinds, all should work. Your TV comes with both the Composite cable jacks and the HDMI ports. For High Definition devices, these connections should be used. Cable boxes typically use both. It is merely a matter of preference. My cable company provides Composite cables with my Digital Box, but that varies with ISP Providers. You can go to Walmart, Best Buy, or any other store local to you and pick up HDMI and composite cables. Gold plated HDMI cables are the best, but expensive. Also, the longer you buy the more expensive it is, so be sure you know just what length you need so you don't buy too long or too short of a length. I hope this helps clarify.
Good Luck,
NOLA Tech
Jan 28, 2010 | Televison & Video
When i first turn on the tv it displays the ''Sanyo'' logo and then goes black. I am still getting sound though, but no picture. Sanyo DP19649
First make sure your HDMI cable is connected from the Cable to the TV; then on the TV Menu check the input; should have a choice of items like, Air, Cable, HDMI, Aux...if you do have an HDMI cable connection, select HDMI and indicate which port #; it could be listed like HDMI/DTV 1 or HDMI/DTV 2; good luck
Aug 11, 2009 | Televison & Video
My picture is not good. I'm hooked up to digital
to get best picture and sound you need to use HDMI connection. This is normally if you have a HD cable box. If you don't have a HD box, use the coax connection directly from the cable line. On your TV, hit the menu button, use the arrow up/down to select manual channel search, select cable and hit enter. this will scan all the digital and analog channels.
Jun 16, 2009 | Sanyo Televison & Video
Set up lcd tv
Make sure of correct input
HDMI is best
cable box must be set to HDMI
otherwise input to channel 3
Jul 22, 2008 | Sanyo DP26746 26 in. LCD Television
Sanyo HD TV
hdmi connection is the best hookup
Nov 20, 2007 | Sanyo PDP-32H1W 32 in. Plasma Television
Televison & Video Logo
226 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
