Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
Reformat from pc to mac
My friend thought he could help me to get started and formated on his pc. Low and behold it wont work on my mac. I do not know how to reformat. Help?
    Scholar:
  • 66 Answers
Since I don't know what Mac you're talking about, nor what version of the OS, I will speak generically.
What your friend did was probably formatted the disk as an NTFS disk. No, you won't be able to see it or access it.
You need to go to Disk Utility, which came with your operating system, and run that. When the utility scans your computer and turns up the drives that are connected, it should show the drive in question (assuming that you have it connected and turned on at the time of the scan).
What you're going to have to do is repartition the drive. When your drive shows up in Disk Utility, it will appear in the left part of the window that displays all the disks and volumes mounted. For the purposes of this discussion, I will define my terms. Volume means the physical hardware, Drive means the partitioned and formatted disk.
If you look at the Disk utility window, on the left are all the volumes and disks displayed. Those are what your computer sees when it scans for drives. For example, on my computer I have 2 drives connected to it. Each drive has a drive name, and a volume name. Mine are: 465.8GB WDC5000 (which is my internal HD/hardware/VOLUME) 500 gb HD (which is the name of the DISK as it appears on my desktop)
1.4 TB Seagate (Hardware/VOLUME) Freeagent Xtreme 1.5 TB HD (which is the DISK name as it appears on my desktop)
Now, you'll want to click on the VOLUME/HARDWARE icon in the left side of the Disk Utility window. When you do this, and you've clicked on the correct icon, you'll notice that it changes the menu on the right side of the Disk Utility window. So you'll know you've clicked on the correct icon, the menu should show five options. First Aid, Erase, Partition, RAID, Restore
Having selected the VOLUME in question, you'll want to click on PARTITION. That will take you to another screen that says VOLUME SCHEME
Assuming that you're only going to be running Mac OS X on this drive, I will tell you to create only (1) one partition. To the right of VOLUME SCHEME you'll see VOLUME INFORMATION. Put in the appropriate information. Select the correct format you want. If you're going to only use this drive on a Mac, then select MAC OS EXTENDED (JOURNALED) and click the APPLY button at the bottom right of the screen. This will repartition your drive and do a low level format. I am assuming that you have no data on this drive, thus there is no need to back up the data.
Once that completes, you'll want to select the disk icon from the left side of the Disk Utility window. The menu on the right will change. It will only display four options. They are: First Aid, Erase, RAID, Restore.
You'll want to click on ERASE In the next window, it should say: Volume Format: Name: Select MAC OS (journaled) for volume format. For Name: put whatever you like Now click on the ERASE button on the right part of the screen.
Once this completes, you should be good to go!
If you're still having problems, you can e-mail me 7ohnnyramone@gmail.com and I will try to help you out.
Best regards, -Ric Carvalho
Posted on Aug 03, 2010
Firelite is formatted for mac only, how do i reformat it to windows or back to the original?
If you are reformatting the disk on a Mac, then open the Disk Utility, then click reformat, and choose the format FAT32. If you have it connected to your PC, go to my computer, right click and select reformat, then choose FAT32.
DISCLAIMER: REFORMATTING AND/OR FORMATTING WILL ERASE EVERYTHING THAT IS ON THE HARD DRIVE. MAKE SURE YOU HAVE EVERYTHING YOU WANT BACKED UP.
Hope this helps!
Apr 25, 2011 | SmartDisk FireLite 40 GB Hard Drive
I bought a StoreJet 25M 640 external hard drive. When i try to use it with my MacBook Pro I am told I have to reformat the HDD. Is this right? How do I do this?
It is dependent on whether you are solely going to use the Hard drive with your macbook or whether you may use it on a PC as well. If you are going to use it with just the mac format it in Mac format if with PC and Mac format it for a PC.
You format the drive using disk utility which can be found by opeing up the applications folder and then the utilities folder. Open up disk utility and then on the left hand side select your hard drive, then select erase from the right. For Mac formatting under Volume Format select "Mac OS Extended (Journaled)" then name the drive and then click "Erase..." For PC formatting under the Volume Format select "MS-DOS (Fat)" Remember reformatting will wipe any information from the drive.
Hope this helps.
Dec 15, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
How do i make my hard drive be recognizable by both MAC and Windows? I have a seagate 500gb external hard drive and I had to reformat it in my HP laptop. After doing so, whenever i use a mac, my hard...
For the MAC to see a PC formatted hard drive, format the hard drive using the PC but format the hard drive in FAT32 not NTFS.
You will then able to transfer files between the PC and the MAC.
The MAC will copy file to the hard drive in PC file format.
Oct 02, 2010 | Seagate Computers & Internet
It wont pick up on my hp computer it was my friend and he had in his mac computer
If the hard drive was formatted on the MAC then the hard drive need to be reformatted using the Windows. If you format as a primary drive in FAT32 then the MAC can read and download files on this external drive so that a Windows PC or laptop can read. These files can be exchanged between MACs and PCs.
Oct 10, 2009 | Western Digital My Book Home Edition 500...
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
I have an 8 GB PNY Attache flash drive that can be read by a Windows XP operating system but not on a Mac OS X operating system. The problem is even more confusing because a Mac that can run both Windows...
You may have the drive formatted in a way that the Mac cannot read. If you go to your "My Computer" in XP, find your drive, right click on it, look for something that says either NTFS or FAT32. If it's NTFS, the Mac won't read it.
You can copy files off the drive and then reformat it, also with a right-click in that My Computer menu. Format to FAT32. FAT32's major limitation will be no files over 2gb each.
There is free software out there that will -try- to read and write NTFS drives. It worked for me, but killed my brother-in-law's Mac.
http://macntfs-3g.blogspot.com/
Dec 05, 2008 | Computers & Internet
Reformatting.
hi there,
you can Format your drive on a Windows machine as "FAT32" and it will be usable both under Mac OS X and Windows. the only thing to make note of is there are some limitations on the FAT32 format, like the 4GB filesize limit and certain naming restrictions.
You can reformat your drive by opening Disk Utility and then reformatting it using that application. in Mac OS X
- In Disk Utility, select the disk.
- Click Erase.
- Choose format from the Volume Format pop-up menu
(select the windows based format).
- Type a name for the disk or volume.
- Click Erase.
- You can use the drive on both the mac and a PC by choosing MS-DOS from the Disk Utility application when you're about to reformat.
Apr 13, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Won't boot
Just reformat, see if that helps.
Oct 18, 2007 | Dell Dimension 3000 PC Desktop
Lacie 250GB External Hardive to be used between a PC and a MAC
Be carefull when moving data from Macs to Windows etc. Your best bet would be to start again. It should work if you get your friend to put the data on the drive & copy it directly to your Mac. From there, you can safely copy data to the PC, but may have trouble accessing that same data after the PC has had it.
Jul 31, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
357 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
