Question about Nakamichi Audio Players & Recorders
Dear Sir I have a Nakamichi BX-300e tape deck.When in play mode the drive motor continuously squeaks, is there anything I can do to remedy this. Thanks Mike Hodgkinson
robotek
  • 1512 Answers
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Posted on Dec 09, 2007
  • 319 Answers
SOURCE: Nakamichi BX-125 Cassette DEck
Unit probably needs belts. Over time, belts may become slack or decompose into tar-like compound. In this case, the deck will need to be cleaned and belts replaced. Take to pro/tech
Posted on Apr 23, 2008
  • 319 Answers
SOURCE: Nakamichi BX-125 Cassette Deck
Check leaf switches and also, press play -- after a few minutes, feel motor(s) for heat build up. If it gets hot, either motor is bad of something is preventing it from rotating
Posted on Apr 25, 2008
  • 319 Answers
SOURCE: Connecting Nakamichi 600 cassette deck to speakers
You must have an amplifier or receiver to connect between deck and speakers. The deck has no power amp
Posted on Aug 03, 2008
  • 11 Answers
SOURCE: My Nakamichi BX 125 won't turn the cassette.
capstan motor not working
belts slipping
Posted on Apr 13, 2009
Nakamichi BX 300 tape deck runs slow in play,belts and idler have been replaced
There is an adjustment in the motor that sets the speed however you need to have a frequency counter and speed alignment tape to adjust the speed correctly. There was also suppose to be oiling of the mechansm at the time the belts were put on.
Jan 05, 2013 | Audio Players & Recorders
Nakamichi bx 300 runs slow in play? Belts and idler have been replaced.
Need either Capstan motor adjustment with speed alignment tape or a new motor requiring the same alignmnet after the new motor.
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
Apr 23, 2008 | Audio Players & Recorders
Apr 16, 2008 | Audio Players & Recorders
Nakamichi BX2 will not take-up tape and play
This may be a reel sensor problem, or the rotation of one of the reels is stopping for some reason. Most of the time, these faults are mechanical. There can be worn belts, or drive wheels, or gears, and etc. Sometimes there are faults in the electronics where a sensor is not being read properly.
The unit should be properly checked to evaluate the fault.
Jerry G.
Apr 06, 2008 | Nakamichi AV-10 Receiver
Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Apr 06, 2008 | Audio Players & Recorders
83 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
