GE washer Mod# WCSR2090D5WW Just runs and doesn't go through cycles
  • Jerry Kerns Aug 04, 2010
    GE Washer
    Mod. # WCSR2090D5WW
    Just runs and doesn't go thru cycles, doesn't fill with water,if I move the timer it will agitate but thats all it will do?
    Thank You!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer. Timers don't often fail, but if every other part of the washer seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Timers can't be repaired, if yours is defective, you’ll have to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 04, 2010
  • Jerry Kerns Aug 10, 2010
    I replaced the timer and no change , If I advance the timer manually the only thing that happens is the pump motor runs, it doesn't fill with water nor does it aggitate.
  • 3,230 Answers
Well first of all you can check timer, if your washing machine fills with water and begins agitating, but the timer never advances or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
You may please follow the steps below to know how to replace timer -
1. Disconnect the power to the washing machine.
2. Remove the timer knob from the control panel by pulling it off the shaft with your fingers.
3. Remove the screws that connect the front of the control panel to the back of the panel using a screwdriver. Rotate the front control panel forward, revealing the switches and wiring inside.
4. Remove the screws that hold the timer to the control panel, using a screwdriver. Disconnect the wiring harness to the timer by pressing in on the plastic tab and pulling it apart.
5. Press the plastic mounting tab at the bottom of the timer down to release the timer from the control panel. Insert the new timer on the control panel by snapping the plastic mounting tab into place.
6. Connect the wiring harness by pushing it into place on the timer until it snaps in. Attach the mounting screws with a screwdriver.
7. Turn the front control panel back over and reconnect it to the rear by attaching the screws. Slide the timer control knob back onto the timer shaft. done!!
Good Luck!!
Thanks
Posted on Aug 03, 2010
  • Jerry Kerns Aug 03, 2010
    It doesn't fill wit water no matter where the timer is set at, also I can hear the pump motor running but no water to pump out.
    I replaced the time and no change, If I advance the timer manually the only thing that happens is the pump motor runs , it doesnt fill with water nor does it aggitate.
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: My GE washer (mod WHSE5240D0WW) will not spin. It
sounds like the motor or the programer has packed up on you more (likley to be motor,) buzzing is the motor trying to turn but cannot,
Posted on Oct 26, 2009
Macmarkus
  • 2605 Answers
SOURCE: GE Washer Mod # WJSE4150
Hi, since your washer is a "belt" drive, I'd suggest checking to see if perhaps the belt is slipping. While you're checking that, make a note of "oil" sprayed around the cabinet on the belt, pulley's etc. These generation GE units are known for tranny leakage/failures. If you're able to remove the front panel from the cabinet, you'll get a much more thorough look at your drive & basket/tub assembly. Just push in the 2 clips on top of the front panel on both sides with a puddy knife or narrow flat screw driver, and pull forward. The bottom just hinges on 2 hangers and the front comes right off. That's a start for now, hope it's a help. Let me know. Good Luck :)
Posted on Oct 28, 2009
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
GE Washer Mod# wcsr2090d5ww
It's normal for some water to stand in bottom of outer tub. It shouldn't be visible in the inner tub though.
Oct 31, 2017 | Washing Machines
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
GE Washer Mod # WJSE4150 click on spin cycle when fisrt engaging, seems to run & spin fine when in second/hiher speed.
Oct 28, 2009 | GE WJSE4150B Top Load Washer
Oct 26, 2009 | GE WHSE5240D Top Load Washer
GE. Washer MOD. WDSR2080DBWW will not stop
Bad water level sensor or tube connection going to control board.
Sep 06, 2009 | GE WDSR2080D Top Load Washer
Loud noise coming from bottom of washer during spin cycle
If it is a ge kenmore it sounds like your tub bearing is dry and needs to be replaced.The reason i say ge kenmore is because they fall under differant companys depending on witch year you bought it
May 07, 2009 | Whirlpool Inglis IP4400 Washer
Washing Machines Logo
182 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
