Question about Pentax Optio S4 Digital Camera
The memory card is showing locked on the camera whenever i try to take photos, it is a pentax opotio s4i digital camera
    Brigadier General:
  • 11,967 Answers
Move the slide switch on the side of the card.
Posted on Aug 03, 2010
I just put a new 4GB SD card into my Pentax Optio S4i camera. When I power it up I get the message "memory card error" Tried another card and got the same error message. Any...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 02, 2011 | Pentax Optio S4i Digital Camera
I used the disk that my PENTAX OPTIO S4i came with, and it successfully downloaded ACDSee on my computer. However, when I plug the camera itself into the USB and turn it on, it is not recognised. It says...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 28, 2010 | Pentax Optio S4i Digital Camera
When ever I turn on the camera, the display shows "card locked". I can hit the > button and it appears to unlock it, since pictures now show up. But, whenever I try to do anything else it locks back...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 11, 2009 | Pentax Optio 60 Digital Camera
Driver does not work
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 18, 2009 | Pentax Optio S4i Digital Camera
Where to find installation software for my pantax optio s4i
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
May 11, 2009 | Pentax Optio S4i Digital Camera
Windows xp does not recognize optio s 4i
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDSee or any other photo cataloging program.
Mar 05, 2009 | Pentax Optio S4i Digital Camera
Built in memory full
Once the computer is restarted - look for the camera in My Computer - it'll show-up as a removable device. Browse & copy the files inside.
Aug 31, 2008 | Pentax Optio S4i Digital Camera
Optio S4i - Freezing problem on green switch
I don't know for sure, but it sounds like it could be a memory card problem. Have you tried it with another card or no card at all? My S4i froze up completely from a bad sd card. The green power button would light up, but nothing else would happen. Pentax recommends Lexar or Panasonic sd cards from what I have heard. My new Lexar card hasn't had any issues.
Sep 08, 2005 | Pentax Optio S4i Digital Camera
Problem in my Pentax s4i
This happens if you go from movie mode into green mode. If this wasn't the case with your freeze, it could be a problem with the memory card.
Pentax Optio S4 Digital Camera Logo
50 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
