Question about Acer Extensa 5420-5687 Notebook
My right speaker is making a rythmic clicking sound. Music and other sounds can't be heard. I've checked on control panel and all seems ok I also did a system restore. any ideas how to resolve this? Could it be a driver problem? (extensa 5420 laptop)
    Sergeant:
  • 235 Answers
Possible but I don't think it very likely. You can try removing and reinstalling the driver but I believe it's the speaker itself. You can get a set on Ebay for about $10.00.
Posted on Aug 03, 2010
I want to know how i can make my cpu start playing music i messed up with the settings and i changed something so now even if i play a song no sound can be heard. please help me out.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 14, 2012 | HP Computers & Internet
Sound card working properly but no can be heard
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
Oct 16, 2011 | Dell Computers & Internet
DigitalBA7500G No sound coming out of the speakers except when put in test mode from the control speaker. Sound out of computer-OK, line from computer to amp-OK, power supply-OK at 12volt AC. Any...
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 12, 2011 | Boston Acoustics BA7500 Computer Speakers
I have a SoundMAX Integrated Digital Audio soundcard in my Windows XP pc and in the Midi Music Syntesizer, I have the following Syenthesizer default sets in the control panel: SoundMAXGeneral MIDI and...
Ok right click on the speaker icon next to the clock and press adjust audio properties, a new window will open up with about 5 tabs on top, click on the audio tab and click volumn under sound recording and another window should open with mic, line in, stereo mix/what you hear etc now if you see stereo mix or what you hear put a check mark in the box so you can play music via the web.
But if you don't see it click on options then click properties and list of name's should appear scroll down and find stereo mix or what you hear and check the box and it should now appear next to the mic.
Hope this helps.
Jul 03, 2011 | Computers & Internet
I want to off the microphone of this speaker but I don't know how. The speaker emits a sound like that of a microphone and it disturbs our listening to music.
if you want to off the microphone
click start control panel sounds and audio devices select advanced there you can a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has or has'nt got a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has'nt a tick in it
click start control panel sounds and audio devices select advanced there might not be a tick in the mute box tick it although it should not interfere with any listening to your music there might be another issue
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps
Jun 26, 2011 | Altec Lansing VS2421 2.1 Speakers
I have an HP Pavilion 6000dv...specifically, it's a 6119us. I have no sound at all. I've checked the device manager, nothing is muted, I've gone through the troubleshooting program...still...
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 28, 2011 | Computers & Internet
My speakers are not working, It seemed the music is playing yet i cannot hear anything... I reformatted my comp and installed drivers, but my sound drive seems not working,, Vinyl AC'97 Codec Combo...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
don
Feb 11, 2011 | Computers & Internet
How to install the mic on this
Depends on your OS
If you have XP do it from the Control Panel (Classic View)
Plug in your webcam
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your webcam mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Vista
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 21, 2010 | Logitech QuickCam Communicate Deluxe...
Sound only in 1 Speaker Instead of Two
not sure if this will help, go to your control panel and then to your sound and audio devices, on the volume tab check to see if both speakers are set to high on the speaker volume option
hope it helps
Jun 13, 2008 | Philips Dynamic Edge 4.1 PSC604 Sound Card
Trouble getting sound from Logitech spreakers/headset
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Dec 27, 2007 | Computers & Internet
Acer Extensa 5420-5687 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
