Question about Lexmark X1270 All-In-One InkJet Printer
Why won't my prinet print? the paper is going through but it is not printing the writing?
  • Lexmark Master
  • 12,061 Answers
Your print heads may be blocked, the ink often drys out inside the tubes and heads and this cause it not to print, try cleaning the heads.
Posted on Aug 03, 2010
Does not write same place
Does not write same place/ print moves on paper/ printed image is in a different place each print
probably the latter
if the image is moving from one page to the next, the cahnces are the paper stop (registration) rollers are not reacting when required, possibly due to a POOR CLUTCH,, replace the registration roller assembly for correct repair
Mar 14, 2014 | Kyocera FS-9130DN Laser Printer
Paper jam
you need to remove the jammed paper, you may need to take the printer apart as much as possible to get it all out, the manual generally has instructions on clearing a jam do you have the manual do you need it?
Oct 20, 2008 | HP Photosmart 3310 Printer
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
Dell printer will not complete task. If printer is uninstalled then reinstalled it will print one time but doesn't complete the task on the "printing screen". I go to the printer window...
Hi Bill,
Have you tried the printers on another PC?Please do.
  • Whats the Operating System on your PC?Do the printer drivers correspond with that Operating System?If not,download the corresponding drivers from this dell support site. This you select under compatibility.
  • After uninstalling the printer,disconnect fully and unplug from power.Reboot your PC before installing the printer again.
Hope this helps.Thanks!
Nov 01, 2011 | Dell V305w All-In-One R840635AU InkJet...
Hi there, my prinet is not grabbing the paper to print it trys it and then say load paper? can it be fixed?
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
May 10, 2011 | Canon PIXMA MP170 All-In-One InkJet...
How to fax.......do the paper go upward or downward on th top
The symbol resembles a sheet of paper with writing/printing on one side. If you see the printing, that's "face up." If you see a blank piece of paper with the corner turned back, and a little bit of printing on the turned-back corner, that's "face down."
May 03, 2011 | Canon MP390 FAX
Last page prints first
usually if you go to the prineter preferences you can reverse the order of the pribnt. This will probably be ona std settings page rather than on the paper selection
Jul 12, 2010 | HP Photosmart C6380 All-In-One InkJet...
Paper not printing on correct side
...possible. go to the printer's website for trouble shooting answers. if nothing found on website, go to there contact page and write them, they may have quick answer for you. 2nd unplug printer and replug in-sometimes this helps.
Apr 29, 2010 | Canon imageCLASS MF6530 All-In-One...
When printing it comes out all double writing
have you tried printing on a different TYPE of paper? I have found if you use the same paper as your printer you get much better results.
Also sounds like you are low on Magenta. the double writing sounds like you need to clean the rollers with a Qtip and a small amount if alcohol. good luck
Aug 14, 2009 | Office Equipment & Supplies
Goes threw the motions but not go
Did you try to replace your ink cartridge ????
Mar 26, 2008 | Canon S200 InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
147 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
