Question about Brother Sewing Machines
I have an NX600 that my $%^&* dog apparently pulled/knocked off the desk onto the ceramic tile floor while I was at work. Everything seemed fine until I started to sew and the electronic warning went off as the needle hit the presser foot. Changed the needle. This time I took one stitch and the tip of the needle broke. Changed the needle and manually turned the mechanism and I can see that the needle is grazing the front of the hole on the throat plate. Did the crash to the floor misalign something? Should I take it to a dealer (100 miles away) for an adjustment?
Thanks,
I have spoken with a Brother dealer in South Bend and plan on taking it there.
Posted on Aug 05, 2010
    New Friend:
  • 194 Answers
Hi,...I think a trip to a service center is in order.I sounds like the needle bar frame is either bent or way out of alighnment.
Doug
My machine stopped feeding the materal thru and got bunched up..then the needle seemed to be hitting on something when i was going sew so i had to quit sewing..i am a new owner so i need help
Please provide the make & model of your machine.
Check that the feed dogs have not been dropped, as for darning. Also, make sure the stitch length is set to at least #2 which would insure there is enough feed dog movement to pull the fabric.
If it's an older mechanical machine, it could be seizing due to old dry oil. If this is the case, it should be addressed before the machine suffers damage. If the needle has been hitting, the needle MUST be replaced because a bent, damaged needle can cause further damage, ie sewing machine timing could be knocked off and require service. Sewing machine timing is usually knocked off when a needle strikes where it should not.
Mar 15, 2017 | Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Feed dog not moving
if the feed dogs are not working correctly, then the machine needs to be serviced
Mar 10, 2012 | Sewing Machines
Not gliding the fabric through??
it sounds like you have a problem with the feed dogs, in the needle plate area check to see if the feed dogs are in the up position, you should be able to feel them with your finger & if not then the machine needs to be serviced
Mar 09, 2012 | Janome Sewing Machines
O.comI'm having a couple of problems: it seems like the feed dogs need to be adjusted because I need to gently pull the fabric through, from the back, otherwise the fabric won't advance & I...
if you have a manual check where your feed dog knob is, push the knob in the opposite direction,,if that doesn't help then something may be wrong with the feed dogs,,you should be able to see the feed dogs in the needle plate area & to feel them with your fingers.
you may need to have the machine serviced at a sewing shop
Sep 21, 2011 | White Sewing 1730 Mechanical Sewing...
I have a Bro PE 400 D. The feed dogs do not seem to be pulling the fabric through without me pulling on it. Stitches are very small even when put on a longer stitch. Embroidery Unit works fine.
check the feed dogs under the needle plate to see if there up or down
if there down then the feed dog switch need to be moved to the up position
but if there up,,,then the machine needs to be serviced so the feed dogs & stitches can be checked
Aug 26, 2011 | Brother Disney PE-400D Computerized Sewing...
Will not feed the material through
Be certain the presser foot lifter handle is down so that it holds the fabric from the top. Then make sure the feed dogs (the little toothy looking things under the presser foot) are up or engaged. Often we'll accidentally knock the adjustment button/lever and the feed dogs go down into the machine and will not come up to provide the pulling action to feed the fabric through. Make sure the mechanics inside the machine are clean and free of dust. And if you see what seems to be a piece of felt around the feed dogs, that is actually lint and prevents the fabric from moving through easily. Use the brush that came with the machine to clean the feed dogs. Hope this helps and happy stitching!
Oct 28, 2010 | Necchi 3537 Mechanical Sewing Machine
Brother nx 600 bottom thread pulls out
Either the upper tension is loose or the lower tension is tight. Tighten the upper tension because it has numbers to refer to.
sewman7
Jul 12, 2008 | Sewing Machines
Sewing Machines Logo
59 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
