I have a Trane XE 90 Furnace Model#TUC100C948B7. My fan inside the furnace is disconnected and thumping around. How can I find out the cause (i.e. belt issue, etc) and can I fix it myself? Where can I find a manual for my unit?
  • 43,501 Answers
The fan part either came loose from the shaft or they often break off of the hub and you will need to replace the blower wheel...
If you take the bottom cover off you can reach into the blower and tell what has ahppened...if it simply is loose then the fix is very easy, there is a set screw that holds it on,just retighten the blower wheel.
I suspect that the wheel is broken and that is much harder, but can be done with simple hand tools...and some time...
Your local dealer can order you a new wheel or they are avaiable of the internet...
How to find Air Conditioning, Heating and Furnace parts online
http://www.fixya.com/support/r4016017-find_air_conditioning_heating_furnace
heatman101
Posted on Aug 03, 2010
Trane xe 90 burner wont light
Bad igniter? Could be a safety control telling the furnace not to light. Check to see if the furnace has a diagnostic indicator. If so count the flashes and then check the diagnostics list inside the door or in the owners manual. This should narrow the problem down.
May 01, 2014 | Heating & Cooling
Trane furnace problems
where? for what? please explain. furnaces tipically have a restrictor where the inducer blower mounts on the furnace.
Apr 05, 2014 | Heating & Cooling
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
I have a Trane xe 70. The Heat is not turning on. The ignitor will glow but NO gas or blower. I turn on the fan and the blower does work but not when HEAT is selected on the t-stat. Also the LED light...
Check to see if you get 24 volts AC at the gas valve from the circuit board when the igniter is glowing. If yes, bad gas valve or blockage in gas train. If no, bad circuit board or broken wire
Feb 07, 2010 | Heating & Cooling
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Jan 28, 2010 | Ruud Central System Air Conditioner
I get 4 blinks it say open limit switch what does that mean
Your induce fan motor senor is out. The little fan motor that take out the heat has a sensor that tells the furnace thats its working. Some time it get stuck. Try blowing and sucking into the tube. you should hear a click
www.fastacservice.com
Oct 16, 2009 | Goodman GMS90703BXA Heater
I have a Trane Xe-60 furnace about 19 years old. During summer months, with thermostat set to deliver air, the outside condenser runs, but furnace blower does not. I can move thermostat lever from auto to...
THIS IS A COMMON PROBLEM WITH THE DOOR SWITCHES, MY FIRST ANSWER WOULD BE REPLACE THE SWITCH SECOND WOULD BE OPEN THE DOOR AND PUSH THE BUTTON IN AND SEE IF THE FURNACE WILL WORK. THIS SWITCH IS JUST A DOOR SAFTEY IF THIS WORKS. I HAVE TAPED A PIECE ON THE INSIDE OF THE DOOR WHERE THE SWITCH WILL HIT THE DOOR ABOUT A 1/4 INCH THICK AND SEE IF THIS WILL GET YOU RUNNING UNTILL YOU CAN GET A SWITCH
Oct 12, 2009 | Omega Trane Furnace Draft Inducer Blower...
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Aug 10, 2009 | Heating & Cooling
Heating & Cooling Logo
303 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
