I have a Zanussi W/M ZWF1640 showing E34 fault codes in diagnostics mone. any clues?
    New Friend:
Zanussi ZWF1440W fails to start wash and goes to end of wash program after a few seconds and unlocks door. E34 error code which suggests, heating element, wiring, water level sensors or PCB! Changed heating element which eliminated the problem for a few weeks.... Then it came back. Tested water level sensors, no issue here. Did some further investigation and found that machine self tests quiescent temperature before starting, this is a resistance measurement, therefore heating element replacement 'fix' made sense as the thermostat is fitted to the heating element and disturbing connections is likely to reduce resistance..... Hence lower temperature reading results in self test passing. So, chased sensor wiring up to PCB mounted at top of machine. PCB easily removed with a few cable ties and simple fix by removing connectors, spraying with WD40 and replacing connectors. Obvious issue when connectors off as connectors appeared cheap and corroded. Worked them back and forth a few times .... And bobs your auntie. Suggest you rework all the PCB connectors to prevent other imminent issues. Philjackson
Posted on Nov 23, 2012
  • Washing Mach... Master
  • 909 Answers
Three things i would suggest on the zannuzi. Does water come into the drum at the beginning of the wash? Does the drum turn if asked to wash or spin? Does the drain motor disperse the water in the drum when supposed to. If motor does not turn, check the brushes. Sorry for being so vague, Zannuzi not common in S.Africa, but those are the common problems i have found while repairing the odd one.
Posted on Aug 03, 2010
E34 code what does this mean
Incongruence between level of electronic
pressure switch and level of anti-boiling
pressure switch 2 (duration of fault at least 60
seconds).
Cycle is blocked with door closed.
Could be: Hydraulic circuit of pressure switches; electronic
pressure switch; pressure switch; wiring between main PCB and electronic pressure switch; wiring between main PCB and safety pressure switch; and finally main PCB.
Dado
Oct 20, 2014 | Zanussi FJS1225W Front Load Washer
I have a fault on my dishwasher it is showing fault code 30 what does this mean?
what brand is it ? then google the brand and the fault no. and you should get an explanation of the code.
Sep 19, 2014 | Zanussi Dishwashers
Frigidaire front loading washer error e34
Click on the link below to download a manual that will give you the information you need.
Click here
Hope this helps
Jan 06, 2014 | Frigidaire Washing Machines
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
I'd like to know the key sequence I need to press to be able to self-diagnose the problem I've got with my zanussi washing machine. ZWF1640.
To display Error Code:
Move Programme Selector to the Off postion.
Press the 2 buttons on the right and turn the selector 1 position clockwise and hold the 2 buttons for about 5 seconds until all the lights are flashing. Release buttons and turn the selector to the 10th position. The Error Code will be displayed.
Note the code then turn the selector to off ,then on,then off again.
Feb 28, 2010 | Zanussi ZWF1440 Front Load Washer
E50 code
hiya
i'm sure that e50/e51 is the insulation in the motor breaking down, in which case its usually new motor time i'm afraid.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 20, 2008 | Zanussi ZWF1640 Front Load Washer
Fabric conditioner drawer does not empty on any of the washing programmes? Any odeas what could be wrong?
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Feb 20, 2007 | Zanussi ZWF1640 Front Load Washer
Washing Machines Logo
405 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
