Question about Whirlpool Refrigerators
Refrigerator too warm, ice forming in freezer
  • Whirlpool Master
  • 909 Answers
Switch off unit completely for 12 hours with doors slightly open. Once totaly defrosted, fan will be free to rotate which means proper cooling will again resume.(If not, have it checked by a Tech. as more complex problems are the cause.)
Posted on Aug 03, 2010
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
The Ice maker in the freezer is not forming ice
freezer is too warm of water valve has failed also ck for ice in the delivery tube . just behind the ice mker .. mm
Aug 10, 2010 | Amana ARS2464B Side by Side Refrigerator
Ice forms on the bottom of the freezer and water leaks on the floor water to the ice maker was turned off and that did not solve the problem.
Assuming that this is a self-defrosting freezer (which almost all are today), the defrosting coil or the timer may be bad. The defrosting coil actually warms up the freezer slightly every X hours. This thaws the ice that starts to form in the freezer. The vapor is then evaporated and exists out through a drip tube to the bottom of the freezer/fridge into a pan. The pan usually has the compressor fan blowing over it to evaporate the contents.
Jul 28, 2009 | Frigidaire FRS6R5EMB Side by Side...
The fridge part of the fridge freezer has a coating of ice forming at the back and it feels warm behind bottom right veggie tray
Sounds like the freezer/refrigerator circulating fan is starting to wear out, When the motor for this fan starts to wear out it does not supply enough circulation for the freezer and the refrigerator. The minimum cost to repair/replace this fan is around $300.00. The immediate solution is to unplug you unit for about four hours allowing the ice that has formed around this fan to melt. Or use a hair dryer to melt the ice, but be very careful not to melt the plastic.
Jul 11, 2009 | Refrigerators
Freezer not defrosting
Most likely there is a leak in your freezer seal allowing moisture to build up and form the ice blockage.
Jun 17, 2009 | Jenn-Air JCD2389G Side by Side...
My GSS22SGRE Side by Side freezer & Refrig temp is too warm
Possible the defrost thermostat is bad and need to be replaced. Not allowing the evaporator coil ice buildup to melt , which acts like an insulation and restricts the air flow in the freezer compartment.
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice forming where ice comes out to refrigerator
I am not sure if this is the same issue or not.  the flap that closes after you have dispensed ice does not close or seal all the way.  The gasket is worn down. the result is warm air get up into icemaker and warms ice and refreezes in one block so now the dispenser gets blocked.  We had to replace the flap in the door.  bought the part at an appliance part  store (not sears) they were helpfull and looked up the part needed.  Also a sheet of ice forms on the  bottom of the freezer.  When water is dispensed a small bit drips inside freezer in back and runs down to botom of freezer slowly forming a sheet of ice.  Use a hair dryer to defrost and then you must unclog the drain in the back at the bottom of ffreezer to allow it to drian.  Once we finally unclogged the drain we have not had any problems for about 2 years.
Nov 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Re: Kenmore Top Freezer formed ice, main refrigerator area is not cooling Kenmore Top Freezer (Main refrigerator area) is not cooling; This trouble shooting has happened for the past year. Main...
not easy to diagnose. the basic fault is that the defrost system has packed up.
check that there is continuity thro the defrost heater. there may also be a thermal fuse in series with the heater so check that also.
if those ok, then points to a fault in the main module
Jun 22, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
