Question about Sharp AR-M208N Copier
We have Sharp AR-M208 N copier/fax machine. We were told that there were no toner cartridges anymore to replace toner in cartridge with fill from a bag. We refilled the toner cartridge and can not get the error saying out of toner to clear.
    Problem Solver:
  • 15 Answers
You probably put the wrong kind in. you can buy a new toner cartridge for this still.
Posted on Sep 09, 2010
My sharp copier ar-m201 displayed toner cartridge near empty and i refill, but still display toner, it now displyed ERROR F2-02, USER GUIDE, and do not allow printing anymore. solution please?
Need to replaced toner cartridge with oem product. there is chip in the unit that communicates with the machine. It needs to be a new one which comes with the new cartridge.
Apr 22, 2018 | Sharp Office Equipment & Supplies
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
Problem with the Sharp -COPIERS - AR165 Call servis F2-04
Hi, this is a problem to do with the toner cartridge.
Answer
  • Try to remove it out and re-insert it.
  • Replace the compatible toner sensor with the old one.
  • Please use Ar 202ft original toner cartridge which fits this machine.
  • Your problem is now solved good times.
Nov 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
Toner explosion
You need to either replace the toner cartridge or empty the sump on the front of the cartridge. The waste sump is in the front of the toner cartridge, It has filled up and has nowhere else to go but out of the sump and where ever it lands. Sometimes they fill up before the toner cartridge is empty. It happens
Jul 30, 2010 | Sharp AR-207 Copier
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Sharp AR-M208N Copier Logo
239 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
