Question about Medion MD 7317 17" Flat Panel LCD Monitor
I have siemens LCD monitor and suddenly the monitor switched off and the power bottom lighted and i pressed on the other bottom and the screen switched on for a moment and off again i do not know what shall i do? please let me know you opinion thanks
  • Medion Master
  • 12,061 Answers
Most likely your power supply has failed as this is the most commonest problem.
The cost of replacement may be more than a new comparable unit, you will have to check.
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Medion, Siemens, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand
Posted on Aug 03, 2010
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
A light horizontal line has appeared on my Samsung UN55C6500 TV. Is there a fix for this?
Horizontal lines on LCD TV,
not usually repairable
plasma may have a corroded or dirty connection on ribbon cable left side of TV looking from the rear
Apr 25, 2017 | Samsung Televison & Video
What stops computer from starting up
hi
turn off the notebook. take a regualr desktop monitor VGA or LCD monitor and plug into the notebook (make sure to power up both the notebook with AC adapter and power cord for monitor). Turn both on and you should see video on the desktop monitor . if you do not see anything, i would hint at the fact that the notebook screen may be bad. Do you hear the hard disk drive spinning when you turn on the notebook ? if so, thats a good indication that the mainboard is still working and that the LCD screen on the notebook is not functioing . You will have to replace the LCD (notebook) screen
Jan 04, 2012 | Acer Aspire 5630 Notebook
When I turn the tv on, the green power light comes on and then immediately turns off, (light goes red). No image or anything comes up on the screen. Never had any problems before this. Checked all plugins....
Use the remote to switch problem,if it's not works,I am sure the power board problem
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
My Fujitsu Siemens LL3200T display suddenly looked very white and with poor contrast. I can only correct the display if I adjust the settings within the graphics card driver away from the default setting....
allan943, As a test, try to swap-in an old known good monitor to your pc to verify pc and graphic's card are ok. Or move LL3200T to a known good pc. If pc is ok, then LL3200T may need warranty work or will need trip to shop for repair of internal power supply. When very strange things start to occur on any lcd screen the first place to investigate would be unit's switch-mode-power-supply!!! This unit should have a 3 year warranty on it. Check with Fujitsu-Siemens to see if they will do a refurb swap-out for you. Please respond with additional comment on what you will or plan to do about this lcd display so all other owners will know what to do. 12fixlouie north of Windy City USA
Apr 02, 2010 | Fujitsu Siemens Computers & Internet
My siemens LCD monitor back light turns off after 1 sec
You need to check out caps in the power supply section first, then check the backlight inverter circuits for bad fuse, transistors. It can also be bad lamps. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 05, 2010 | Fujitsu Siemens Siemens Basic Line B15-1...
Medion MD 7317 17" Flat Panel LCD Monitor Logo
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
