Question about Brother Fax-1360 Plain Paper Inkjet Fax
Hi I want to get the answering service off as i cannot receive any faxes.
  • 32 Answers
Just do these steps
Easy Receive ON : Press Menu 2-1-3 & choose easy receive on.
Distinctive Ring OFF : Press Menu 2-0-3 & choose to off.
Then Press receive mode to FAX only.
Posted on Aug 03, 2010
Cannot receive a FAX but can send FAX on a HP Photosmart C7180 All-in-One
are you using the same line for fax and phone???
are you using a Telephone Answeing machine or a Voice Mail??
However you can follow the following steps
1. Press the power button to turn off the HP fax product.
2. Wait for 20 seconds, and then press the power button to turn on the HP fax product, and then connect one end of a two-wire telephone cord to the telephone jack and the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
3. Make sure that there is plain white paper in the input tray.
4. Press the Setup button on the product Control Panel.
5. Press the down arrow to select Tools, and then press OK.
6. On the Tools menu, press the down arrow to select "Run Fax Test", and then press OK. The Fax diagnostic test prints.
7. Review the report.
If the test lists faxing issues and solutions, the fax test failed.
Try the steps on the printout to troubleshoot the issue as the report is specific to your product and faxing environment.
Repeat the fax test after fixing the listed faxing issues to make sure the test passes. Try to receive a fax.
Okay, next, we need to make sure that the Auto Answer feature is turned on by following the steps below:
When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls.
1. Press the Setup button on the product Control Panel.
2. Press the down arrow to select Basic Fax Setup, and then press OK.
3. On the Basic Fax Setup menu, press the down arrow to select Auto Answer, and then press OK.
4. Press the down arrow to select On, and then press OK.
5. Try to receive a fax.
Since the issue persists, the problem could be due to some conflicting telephone services.
The following telephone company services might block or interfere with incoming faxes:
Distinctive Ring Service: A distinctive ring service, if it is available from the telephone service provider, often resolves this issue.
* Voice mail: It is possible to use the fax in manual receive mode while using a voice mail service. For manual receive mode, turn off auto answer and press "Start Fax Black" or "Start Fax Color" on the control panel before the voice mail picks up the line to start receiving the fax.
* Call waiting: Do not use a call waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
* Privacy block
* Security screen
* Anonymous call rejection
* Privacy manager
* Any other service that screens or intercepts incoming calls
If any of these services are on the telephone line connected to the HP fax product, contact the telephone service provider for its recommended solution.
After addressing any existing conflicting telephone services, try to receive a fax.
Try contacting telephone people
try changing the settings below
2. Press the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Fax Speed, and then press OK.
4. Use the down arrow to select Medium, and then press OK.
5. Try to receive a fax again. If the HP fax still cannot receive a fax, try lowering the fax speed even further
Next, change the "Rings to Answer" setting on the HP fax by following the steps below:
2. Press the right arrow key to select Basic Fax Setup, and then press the OK button.
3. Press the down arrow to select Rings to Answer, and then press OK.
4. Use down arrow to select the desired number of rings, and then press OK. you cn change the rings to answer to 6 if your telephone answering machine picks up the call after 4 rings.
If the HP fax still cannot receive a fax, change the following steps
2. Use the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Error Correction Mode, and then press OK.
4. Use the down arrow key to select Off, and then press OK.
1. Plug the telephone cord directly into the telephone jack and not through any other device.
2. If present, remove any splitters or other devices attached to the line, except for a DSL filter.
3. If the telephone cord is over 3 m (10 ft) long, move the fax closer to the telephone jack, and then use a cord 3 m (10 ft) long or shorter.
4. Connect the other end of the telephone cord directly to the back of the HP fax product into the port labeled 1-Line.
5. If other devices such as, telephone answering machines or computer modems, are attached to the telephone line, remove them. If devices attached to other extensions of the same telephone line are present, remove them for this test.
6. Try to receive a fax.
If removing telephone devices and connections allows the HP fax product to receive faxes, this indicates interference from one or more of the removed devices. Interference can be caused by incompatibility or by using too many other telephone devices at once. Telephone devices can be added back but test after adding each to make sure that they do not start to interfere again.
If the HP fax product still cannot receive a fax after removing other devices, continue with the following steps:
7. If a DSL filter is needed on the telephone line, change the DSL filter and then try to receive a fax. If the HP fax product still cannot receive a fax, proceed to step 8.
8. If a new telephone cord has not been tried, change the telephone cord to a new two-wire telephone cord, and then try to receive a fax again.
if it does not resolve then perform the following steps
1. Disconnect the power cord from the back of the product.
2. Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel.
3. Connect the power cord to the back of the product and then release the buttons when the product turns on.
4. The product resets to factory defaults.
As a last step, test in another location by following the steps below:
If possible, move the HP fax product to another location with a separate telephone line (another house for instance).
Try to receive a fax at that location, and if you are able to receive faxes from the changed location, then your telephone line should be tested.
If it resolves well and good if it does not then service the printer
Dec 12, 2012 | HP Photosmart C7180 All-In-One InkJet...
I can send faxes but cannot receive them fax test tells me there is no dial tone detection
* Privacy block
* Security screen
* Privacy manager
Oct 28, 2012 | HP Photosmart C7180 All-In-One InkJet...
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cannot receive faxes
Faxes cannot be received but they can be sent Review the following information to determine why faxes are not being received.
  • Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, or Privacy Manager? These phone services are meant to prevent unwanted calls, but they will aslo stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  • If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  • If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Click here to go to the Drivers and Support page .
    2. Type in your model number (HP PSC 2210xi for example).
    3. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    4. On the software download page, select your operating system version.
    5. Locate and select the firmware update.
    6. Follow the directions to download and install the update
  • If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (buu04072) (in English).
  • If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (buu50333) (in English) to learn how to correct these problems.
  • If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or the problem cannot be determined section of this document.
Jun 24, 2009 | HP Officejet 4110 All-In-One InkJet...
Cannot send or receive faxes
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
I can send faxes from my HP J3640 but I can't receive them. The instructions mention turning on "auto-answer", but there is no button or nothing in the menu for "auto-answer". How do I turn on auto-answer?
Issue The product cannot receive a fax, but it sends faxes successfully. All other functions work correctly. Usethe following solutions in the order presented to resolve the issue.When one of the solutions resolves the issue, there is no need tocontinue troubleshooting. Solution one: Run a fax diagnostic test
  1. On the product control panel, press the Setup button (c01461502.gif).
  2. Press the Right Arrow button (c01185072.jpg) to select Tools.
  3. Press the Right Arrow button (c01185072.jpg) to select Run Fax Test, and then press OK. The fax diagnostic test prints.
  4. Review the results of the test.
    • If the test lists faxing issues and solutions, the fax test failed. Follow the solutions on the printed report totroubleshoot the issue. This report is specific to your product andfaxing environment, so try the solutions on the report before tryingthe next solution in this document.
    • If the test does not show faxing issues and solutions, the fax test passed. Continue to the next solution.
Solution two: Test the receiving function Follow these steps to make sure the receiving function works correctly.
  1. Makesure the originator of the fax has the correct fax number for yourproduct, and then ask that person to send a test fax to your product.Watch the control panel display and listen to the sounds the productmakes.
  2. Review the results of the receiving function test:
    • If the product receives the fax correctly, you resolved the issue. You do not need to continue troubleshooting.
    • If the product does not ring or does not answer the call from the other fax machine, ask the originator of the fax to send the test fax again. If the second try fails, go to Solution eleven in this document.
    • If the message on the control panel reads ' Answering' and does not change to ' Connecting', the product is not detecting the other fax machine. Go to Solution eleven in this document.
    • If the product rings briefly, and then stops, another device answered the call. Continue to the next solution to continue troubleshooting.
Solution three: Check for conflicting telephone services Many telephone companies offer services that prevent unwanted calls. The following services might block incoming faxes:
  • Voice mail
  • Privacy block
  • Security screen
  • Anonymous call rejection
  • Privacy manager
  • Any other service that screens or intercepts incoming calls
If any of these services are on the telephone line connected to theproduct, contact the telephone service provider for its recommendedsolution. A distinctive ring service, if it is available from the telephone service provider, often resolves this issue. Solution four: Use an analog phone service HPdesigns Fax and All-in-One products to work with analog telephoneservices. These products might experience some difficulties whenconnected to phone lines with digital services. For best faxingresults, connect the product to an analog telephone service. To obtain digital services information or support, contact the telephone service provider or your system administrator. Solution five: Check the fax connections
Jan 03, 2009 | Office Equipment & Supplies
Receiving a fax
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Problem with the fax
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Oct 24, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fix my fax
Oct 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Brother Fax-1360 Plain Paper Inkjet Fax Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
