Question about Troy Bilt Bronco 208cc 4Cycle Gas Powered Rear Bolo Tine Tiller
Troy Built Tiller - How much oil does it take?
  • Troy Master
  • 8,404 Answers
About a quart ... but dont overfill. There is a dip stick on the engine.
Posted on Aug 03, 2010
4 Suggested Answers
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
  • 3 Answers
SOURCE: changing the drive belt
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Posted on May 13, 2009
SOURCE: Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
Posted on Mar 31, 2010
Oil capacity for a Troy Built tiller Horse Kohler engine?
start adding little at a time keep checking until full remember how much it took
Apr 25, 2018 | Troy Garden
Tiller moves to fast on a troy built rear tine
what do you mean - are you sure this is a husqvarna or a troy built tiller?
May 07, 2012 | Husqvarna PRRT850X 960920015 CA 17" Rear...
What type of oil does a troy built tiller use? I have lost my book.
This is dependent upon what the engine application on the tiller is. If it's 2-stroke, use a quality synthetic or semi-synthetic 2-stroke oil mixed with the gas. If it has a 4 stroke engine use SAE30 oil, unless you run synthetic (which I highly recommend), then you can use a multi-viscosity oil if you like, say 10W-30.
May 24, 2011 | Troy-Bilt Pony Garden Tiller
Where is the model # on troy built tiller
If this is a genuine Troy ... (built in Troy, New York, by Garden Way) find the information stamped on the transmission housing left or right near the tire.
May 03, 2010 | Troy-Bilt Pony Garden Tiller
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Bronco 208cc 4Cycle Gas Powered Rear Bolo Tine Tiller Logo
708 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
