Question about Vacuums
The power on my cuisinart microwave is coming on, but I cannot get the other controls to come on. The microwave is not even two years old, and is hardly used.
  • 909 Answers
If there is no responce on 2 or more buttons, the board is certainly in need of replacement. Normally one button indicates the toutchpad. Need to put on a surge plug to remove unstable voltages.(In S.Africa, we call the protection plugs "surge plugs").
Posted on Aug 03, 2010
Why does the power brush turn on even when turned off?
If it is 6 months old, it should be under warranty. Call wherever you purchased the vacuum and ask how they handle warranty claims.
May 15, 2015 | Vacuums
Microwave, just stopped working, no lights , nothing. 4-5 years old GE Profile Eterna
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 24, 2011 | Vacuums
My Cuisinart Griddler Combo instructions tell you how to store the temperature control probe. I did not receive such with my griddler. Should there be one in the box?
Hello, W/D here.
Usually, the probe is built into the power cord, and is the long part that sticks out past the power connections. My best guess is that it is there.
Best regards, --W/D--
Feb 09, 2011 | Vacuums
The microwave will not work. I tried the power button, the timer, the food, none of the areas to touch on work.
the safety switch is burn or broken.
also check for roaches they like to hang inside a microwave, you be surpise that you might have no roaches, i said the same thing, til i found a few.
anyways, how old is the device if it like 4 years old might be curcuit board going bad.
touch pad might be bad. usually be better to buy another microwave then to get it replacable pad.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Oct 29, 2010 | Vacuums
Trying to purchase an Emerson microwave splatter shield replacement part. Cannot find a vendor to purchase from. MODEL #MW8992RD
EMERSON MICROWAVE-IF THE SHIELD (METALLIC CARDBOARD THEY CALL SPLATTER SHIELD) IS BURNT OR HAS BLACK SPOTS THROW THE MICROWAVE AWAY. MY SHIELD CAUGHT ON FIRE. MICROWAVE ONLY 3 YEARS OLD. DON'T BUY EMERSON.
Sep 22, 2010 | Vacuums
Microwave light turns on makes noise no heat
If it's a bad magnetron and the unit is just a few years old call the
manufacture. they will replace the mag. you pay the labor. If it's bad transformer/control board cheaper to buy a new one.
Aug 11, 2010 | Vacuums
I have an Amana above range Radarange, Model #AMV4204AAB, Serial # 10168958GE. Tonight after running for a 7 minute period and finishing, it would not again start. There is power to it, but various...
  1. Push the power cord all the way into the outlet in case it became loose and is causing the problem. If the microwave still isn't working, check for a blown circuit fuse, and repair it.
  2. Step 2 Check that the controls on the microwave are programmed correctly according to the owner's manual. If they aren't, program them.
  3. Step 3 Close the microwave door firmly. Touch the cook function on the Start Pad, not the timer. Check if the microwave works. If not, continue to step 4.
  4. Step 4 Program the Power Level correctly. If it's not programmed properly, the microwave will cook the food too quickly or too slowly.
  5. Step 5 Use only microwave safe dishes. Make sure food is evenly shaped and defrosted before placing it in the Amana Radarange microwave.
Thanks.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 09, 2010 | Vacuums
Have a two clear view probably 3 year old belts
sounds like the motor bearings are bad. when those bearings wear out the motor shaft doesnt stay strait and allows the belt to track off.
Jan 16, 2010 | Bissell CleanView 3596 Bagless Upright...
Electrical power down while vacuuming (not a reset)
Thank you JonahBegone!
My 4 years old Silver Moon has been power down off and on for a couple of months, but all of sudden it kept doing it. Then the power won't turn on when I plugged it in ( this turns out to be another problem, see my other posting). I took your advice on taking the hose and handle apart. I unscrewed the 5 screws, but can't pull the handle apart to look inside. I was able to see the 3 metal contact on the hose that you mentioned through a 1/4 inch gap when I forced the handle apart. I cleaned the black stuff off through the little gap by rotating the hose a few times. Then magically, my power down problem also went away. Thank you once again.
Mar 25, 2008 | Miele s558 Silver Moon Vacuum
No Power coming thru hose handle
It probably wouldn't help, it sounds like the switch. Have you tried pushing the reset button? (It's a little red button on the end of the power nozzle.)
Feb 24, 2008 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
