Question about Samsung S860 Digital Camera
Card Locked! Will not let me take pictures.
Card Locked! How do you unlock card. I am unable to take pictures.
    Brigadier General:
  • 11,967 Answers
Move the slide switch on the side of the card.
Posted on Aug 03, 2010
L have a sensory pleasure nv3 camera but l am unable to take a picture due to card locked how do l cancel this problem
There is a small slider switch on the side of the card slide it to 'unlock' and try again
Feb 15, 2015 | Cameras
Card is locked and I am unable to unlock it
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 26, 2014 | Pentax Cameras
MEMORY CARD LOCKED
All SD cards I have ever seen can be locked with a little slide on the left side as you face the label. if the slide is up, the card is unlocked and can be used for taking pictures. If the slide is down, it is in the locked position, which prevents it from overwriting anything that is currently on the card. Before you unlock it you may want to verify that all pictures on the card (if any) have been saved because once you start using the card and overwriting its contents, the pictures are gone forever. If the card is empty, just unlock it, format it and start taking pictures.
Dec 22, 2013 | Nikon D3000 Digital Camera
I am unable to take a picture, the screen says protected card. How can I clear this?
Pull the memory card out, along one edge you will notice a small switch slide it over to unlock the card. The switch that is furthest from the contact is in the locked position so no pictures are erased.
Jan 29, 2011 | Fuji FinePix J10 Digital Camera
Receiving "card locked" message and unable to take
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Dec 20, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
I am unable to take any pictures, I can only review the pictures and movies I have already taken. On the screen it says Card Locked. How do I unlock the card? so if the switch is damaged does that means...
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.The switch doesn't actually control anything on the card, it engages a sensor on the camera. Thus you could glue something onto the card in place of the switch.
Oct 20, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card problem
Hi and welcome to FixYa.
I'm not sure about your particular instance, but this can happen if you change up cameras or use a card reader.
As for being unable read the memory card, sometimes the card can be switched off by accident. Turn off the camera and remove the card. Look at the side of the card and there will be a little switch. One end says locked (or shows a little picture of a locked lock) and the other end says unlocked (or, shows a little picture of an unlocked lock). Just move the switch to unlocked.
Try that, and let me know with a comment if that doesn't work, othewise, thanks for coming to FixYa!
Rob
Mar 02, 2009 | Kodak EasyShare One Digital Camera
Memory card locked!
There is alittle slide on the memory card.
Take it out. Look for it. Depending what you have it may be yellow, look on the left. If it's down, slide up and it will be unlocked. :)
Apr 19, 2008 | Canon PowerShot A520 Digital Camera
Card locked canon powershot sd750
Check the switch on the side of your SD memory card. It is a small sliding switch which has a lock position. Sounds like the switch is in the "locked" position. Unlock, reload card, & you should be good to go. If not, the card is probably damaged.
Mar 01, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
Samsung S860 Digital Camera Logo
123 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
