Question about Dishwashers
Dishwasher panel has no power
I have a kenmore quietguard 3 dishwasher and it acts as if it has no power. the line going to it is hot. Is there a fuse and if so where? thanks
  • 1 more comment
  • floydoliver Apr 25, 2008
    how do i access the control panel?
  • klcasas Jul 07, 2008
    My dishwasher turned on as normally but shut off before the end of the last drain cycle and now is getting no power, checked power supply and everything is fine. I have had many problems with the electronic board. It is 4 years old and had the electronics board changed at 20months had problems again with the machine coming on sometimes and not on other times but I always had power.
  • Anonymous Dec 25, 2008
    i want my dishwasher fixed.
    hellllllllllllllp!
    Genius:
  • 1,073 Answers
On some of these there is a fuse it is located on the side of the control board it is a thermal fuse not resetable if it is blown it has to be replaced
Posted on Apr 25, 2008
I need an instruction manual for a new Kenmore Dishwasher
go to kenmore web address its there.adrian,,,,
Jul 13, 2010 | Kenmore Dishwashers
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Apr 28, 2010 | Kenmore 24 in. 17002 Built-in Dishwasher
Should the QuietGuard Ultra Sound Insulation on my Kenmore Elite dishwasher become hot enough to allow the barrier under the front panel of the door to melt and break off?
Probably not. Check the insulation and see if it's all there and in place. If the insulation looks fine then the problem may be that your water heater(the one that supplies hot water to your whole house) may be set at too high of a temperature, there should be instructions on how to adjust the thermostat somewhere on the water heater.
Mar 13, 2010 | Dishwashers
Hello, i have a Kenmore Quietguard standard dishwasher. it is in the "lock" position under dry options and the dishwasher will not start. can you tell me how i might be able to re-start this?
On our Kenmore Quietguard the lock light is at the Air Dry button. Holding the Air Dry button for about 8 seconds turns the lock light off if it is on and on if it is off.
Jan 04, 2010 | Kenmore Dishwashers
Why does my Kenmore QuietGuard Dishwasher Whistle?
Is it during the wash cycle? That is air getting past the drain flapper. If you install a trap in the drain line it should go away.
eric
Jun 29, 2009 | Kenmore Dishwashers
Kenmore quietguard standard wont start.
is there any function at all? if not, check thermal fuse located inside near control panel, check www.searspartsdirect.com and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Jun 25, 2009 | Dishwashers
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
check the water inlet valve first
May 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
441 people viewed this question
Top Dishwashers Experts
