Question about Garmin nuvi 205W GPS Receiver
My garmin nuvi looses gps connection goes to a black screen reloads maps 3 or 5 times
    Scholar:
  • 66 Answers
Your Garmin need to be reset.
Go here: http://www.garmin.com/garmin/cms/site/us/extras/downloads
and download latest maps. Also check
http://www8.garmin.com/support/download.jsp
Where you'll find software updates for your GPS.
Posted on Aug 03, 2010
I have a nuvi 265w garmin. It turns on and then turns off without loading the map
The GPS battery may need to be charged.
Does the GPS turn on when connected to a vehicle power cable?
Running the Garmin WebUpdater to load or reload the latest software will usually fix any bugs.
Contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 23, 2012 | Garmin Nuvi 265W GPS Receiver
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
Garmin Nuvi 1350 showing on screen "no map data available"
Shut off the nuvi.
Remove any memory card (if equipped) from your nuvi.
Plug the GPS into your computer via USB cable.
Open the Garmin "drive" icon in "My Computer"
Navigate to the x:/Garmin directory or "folder" (where "x:" is the drive letter assigned to your Garmin). Locate either map files set(s) named: gmapsupp.img or gmapprom.img.
Some units store map files in the hidden x:/.System directory instead. To view the .System folder and contents, you must direct your computer to display both the "system" and "hidden" files.
If you lack large files named either gmapsupp.img or gmapprom.img (about 1 GB or more); your maps are missing from the internal memory of the nuvi and will need to be reloaded.
If you pulled a memory card above, reinsert it and check the directories for the same gmapsupp.img or gmapprom.img files. If they're not present there, the maps should be reloaded.
I hope this helps
Sep 15, 2011 | Garmin nuvi 1350 Car GPS Receiver
Once I conect my GPS to a usb cable, I get the black screen that says conect to computer, that being connected to the car. I thought that the gps needed to be coneected to the internet to get updates, I...
The screen your describe on your Garmin Nuvi is quite normal. It's the PC communication mode of the Nuvi. When disconnected from the PC it will automatically restart.
To update Nuvi software and maps - connect the Garmin to a PC / Mac using an USB cable. Then start your web browser (Internet Explorer / Firefox or similar) and go to MyGarmin.com.
To update the Garmin - MyGarmin.com will check if your webbrowser has been installed with the Garmin update plugin. If not it will say so and will lead you through the procedure to install the Garmin web browser plug-in.
After the web browser plugin is installed it will ask you for your Username and Password at MyGarmin.com. If not registered, then register yourself with the serial number of the Garmin Nuvi.
From here it's possible to update your Garmin Nuvi with new Nuvi software and maps using your username / password at MyGarmin.com
Jul 09, 2011 | Garmin Nuvi 1300 GPS Receiver
Reloading map Screen blank
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 04, 2010 | Garmin nuvi 1300 Car GPS Receiver
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
I've updated my map for garmin nuvi 310 through malfreemaps but it did not work well. The map did not display as detail as they preview. I also lost the guidance voice. And my car picture keep off the most...
It sounds like you may have wiped out the Garmin internal maps with the malfreemaps and they aren't compatible with your unit. You'll have to send it in to Garmin to have them reload the units software and maps.
Oct 14, 2009 | Garmin nuvi 310 Car GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
262 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
