Question about Gaggia Titanium Espresso Machine
Display saying GRINDER
I have a message in the display saying GRINDER BLOCKED.
I have cleaned the grinder but still the same message?
    Problem Solver:
  • 3 Answers
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Posted on Jan 24, 2013
  • Ari Frankel
    Ari Frankel Jan 16, 2016
    Do you have the repair manual for the ESAM 6700?
My machine does not say grinder block but it saying coffee bean holder is empty when it is full.
Posted on Aug 10, 2010
Saeco incanto says brew unit blocked
The message is likely generated because your grinder burr disk is ether stuck or turning too slow.. If you're a handy person, you can open up the casing, access the grinder assembly and clean it. If your grinder is clean and you still the message, may be the rotation pick connector got loose (it's the one with the 2 small black wires) or iss defective.
Mar 17, 2013 | Saeco Coffee Makers & Espresso Machines
My Saeco Royal Professional won't grind: "blocked grinder" message
Hello, I had exactly the same problem. In my case, it seems that the grinder was not ejecting the grounds into the doser with enough force to move the pressure plate and trigger the microswitch. My grinder motor might be wearing out, but I decided to try increasing the sensitivity of the microswitch before I spent so much. I replaced the microswitch, but that didn't solve the problem. Instead, I added a spacer (~2mm, but you'll have to play with it to adjust the pressure for your switch) between the doser pressure plate lever arm and the microswitch. That has been working very well for the last month. Very occasionally I get the same message again, but if I tell it to brew again the second grinding succeeds. I hope this helps!
I got the replacement microswitch at http://www.saecoparts.com/
May 19, 2012 | Saeco Royal Professional Espresso Machine
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
Grinder blocked
One posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Jun 04, 2010 | Saeco Royal Professional Espresso Machine
"grinder blocked"
You can try th clean the grinder following the instructions here below
http://www.fixya.com/support/r5572092-saeco_italia_automatic_espresso_coffee
Good luck and thanks for your vode
May 08, 2010 | Starbucks Saeco Italia Digital Barista...
Incanto sirius states grinder blocked. Took apart
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
New grind and display shows "grinder blocked"
This normally indicates due to the grinder being set too fine or oily beans being used.
Try setting the grind on 7 .
If it still fails the grinder will need to be unblocked and serviced.
Dec 07, 2009 | Gaggia Titanium Espresso Machine
'Grinder Blocked' error message
The grounds chamber is clogged, you will have to open the machine and clean out the chamber on the side of the grinder, it is the one covered with the little door, you might be able to get to it if you dremove the brew unit.
May 03, 2009 | Gaggia Titanium Espresso Machine
"COF. BEANS EMPTY" message
Here is a link for completely cleaning the grinder - this often fixes the problem:
http://www.cerinicoffee.com/Saeco_technical_documents.asp
Nov 12, 2007 | Saeco Royal Digital Plus Coffee...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
1,111 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
