Intermittent horizontal line - Televison & Video
    President:
  • 1,099 Answers
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 03, 2010
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Horizontal Lines and distortion
It sounds that the T'Con board has the fault. Check all the cable connections to LCD pane to T'Con board for firmness.
Jan 03, 2013 | Televison & Video
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
TV: vertical colored lines on TOSHIBA TV Model 36ZP46P
HAI,1.REPLACE SOME CAPICTORS IN HORIZONTAL SECTION.
       2.ADJUST FOCUS ON LOD(EHT TRANSFORMER).
       3.REPLACE HORIZONTAL OUTPUT TRANSISTOR.
Jul 05, 2008 | Televison & Video
Horizontal blue line
The intermittent horizontal line is cause by a loose solder connection in the vertical amplifier IC.
The IC is mounted on a heatsink nearby or around the flyback transformer.
The way to fix this failure is to add fresh solder where you see some brown spots on the circuitry that were cause by components getting hot.
Good Luck.
Jun 20, 2008 | Sharp 25R-S100 25" TV
Intermittent problem
Could be dry solder near vertical Ic and horizontal Output Transistor.Resolder components mounted on heatsinks.
Samir.
Mar 09, 2008 | LaCie Electron 19" CRT Monitor
White intermittant horizontal lines
Sure it can be fixed, I think some components on the main board needs resolder on their soldered joints. Try this first before thinkig of getting a new one.
Nov 30, 2007 | Videoseven W17PS 17" LCD Monitor
Horizontal lines on NEC plasma
Intermittent horizontal deflection
Resoldered the pins of horizontal deflection transformer
Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Geometric distortion, Pillow, and picture enlarged horizontaly
The problem was a short from GND to pin 11 inside IC301 (TDA8350Q). This pin is the output of amplifier for geometric correction signal. Replace IC301
Nov 26, 2007 | Televison & Video
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Electro Med Services...
