Cannot turn the tv on the on button just flashes red 4 times then red 5 time
    President:
  • 1,099 Answers
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help to solve the problem
Posted on Aug 03, 2010
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Thomson scenium LED error code 45
When i turn it on red light flashes 3 times then 1 time, this keeps on repeading, no sound, no light
Sep 30, 2009 | Televison & Video
TV won't turn on. Red power button flashes then shuts off.
Did the TV work but with a convergence eproblem before you changed the STK's.? If so it is very likely you have misplaced one of the several leads when reassembling the set. It is ususally a perfect cure. Power light flashing 4 times indicates this type of problem.
Feb 21, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
TV won't turn on and red light flashes 6 times.
MINE DID THAT AND IT WAS THE THERMOSTAT FOR THE BULB
Jul 14, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
